This teardown is not a repair guide. To repair your Qoobo - Robot Pillow with a Tail, use our service manual.
  1. Qoobo Teardown, Remove outer cover: step 1, image 1 of 3 Qoobo Teardown, Remove outer cover: step 1, image 2 of 3 Qoobo Teardown, Remove outer cover: step 1, image 3 of 3
    • Unzip, and remove.
  2. Qoobo Teardown, Remove screws near charging port: step 2, image 1 of 2 Qoobo Teardown, Remove screws near charging port: step 2, image 2 of 2
    • Remove the circular sticker around the charging port. This reveals two screws, which should also be removed.
  3. Qoobo Teardown, Remove screws under power button: step 3, image 1 of 2 Qoobo Teardown, Remove screws under power button: step 3, image 2 of 2
    • The power button can be dislodged with a small knife, revealing another 2 screws.
    • Once these screws are removed, the plastic plate should come loose and can be removed.
  4. Qoobo Teardown, Remove the inner cushion shell: step 4, image 1 of 3 Qoobo Teardown, Remove the inner cushion shell: step 4, image 2 of 3 Qoobo Teardown, Remove the inner cushion shell: step 4, image 3 of 3
    • Unzip the inner fabric shell, and remove the plastic "heart" of the device.
    • The tail has 2 degrees of freedom. One servo is used for the X axis, another for the Y axis. The tail itself is made up of springs, with stretchable cables acting as "tendons"
  5. Qoobo Teardown, Close ups of the main board: step 6, image 1 of 3 Qoobo Teardown, Close ups of the main board: step 6, image 2 of 3 Qoobo Teardown, Close ups of the main board: step 6, image 3 of 3
    • U1: reads "CB5121". Probably a PMIC
    • U4: Unmarked 32 pin IC is almost certainly the main microcontroller.
    • U3: BMA223 Accelerometer (used for detecting motion, for when the pillow should wag its tail)
    • U7: Unmarked 14 pin IC.
    • There is an unpopulated 6 pin header that looks like a serial port (UART)
    • There is an unpopulated 8 pin header that is probably for debug / flashing
  6. Qoobo Teardown, Other boards: step 7, image 1 of 3 Qoobo Teardown, Other boards: step 7, image 2 of 3 Qoobo Teardown, Other boards: step 7, image 3 of 3
    • Simple board for the power switch.
    • Another board has the charging port and LED
    • Ni-MH battery rated at 6.0V and 1300mAh
  7. Qoobo Teardown: step 8, image 1 of 3 Qoobo Teardown: step 8, image 2 of 3 Qoobo Teardown: step 8, image 3 of 3
    • Servos are unmarked, but appear to be standard hobby-grade servos.
Nic Dahlquist
157 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 926
