This teardown is not a repair guide. To repair your Philips Bluetooth adapter AEA2700, use our service manual.
  1. Philips Bluetooth adapter AEA2700 Teardown, Philips Bluetooth adapter AEA2700 Teardown: step 1, image 1 of 3 Philips Bluetooth adapter AEA2700 Teardown, Philips Bluetooth adapter AEA2700 Teardown: step 1, image 2 of 3 Philips Bluetooth adapter AEA2700 Teardown, Philips Bluetooth adapter AEA2700 Teardown: step 1, image 3 of 3
    • here you can see the view from the top, the bottom and the backface - device is really tiny: only 7,5cm in diameter!
  2. Philips Bluetooth adapter AEA2700 Teardown: step 2, image 1 of 2 Philips Bluetooth adapter AEA2700 Teardown: step 2, image 2 of 2
    • Remove 2 of the rubbers on the bottom side - you'll find 2 screws afterwards>> unscrew them ;)
  3. Philips Bluetooth adapter AEA2700 Teardown: step 3, image 1 of 1
    • now simply remove the top cover.
  4. Philips Bluetooth adapter AEA2700 Teardown: step 4, image 1 of 1
    • there's only one external component connected by cable: the NFC tag
    • it's easily possible to remove the circuit
    • lift it on the front side of the device
    • and pull it this direction - it helps to push at the cinch connector!
  5. Philips Bluetooth adapter AEA2700 Teardown: step 5, image 1 of 2 Philips Bluetooth adapter AEA2700 Teardown: step 5, image 2 of 2
    • Front- and backview of the circuit
  6. Philips Bluetooth adapter AEA2700 Teardown: step 6, image 1 of 1
    • when reassembling take care to stick the NFC tag to the correct location in the cover
RFischer
265 Reputation
2 Guides authored
One Comment
Hello. Is there any way to use this device in a car through an adapter or modification?
Fabio Passarelli - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 17
All Time: 3,985
