Nest Temperature Sensor is a complementary device for the Nest Thermostat E or 3rd gen. It is created to help customers measure the temperature exactly where needed and control the thermostat accordingly
Positioned as a premium device, this Sensor is made from quality soft-touch plastic and comes in a decent box
The Sensor uses a single CR2 battery (included)
Diameter: 50mm, height: 22mm
The back of the Sensor has a simple screw, which gives us access to the battery
Removing 4 Torx T7 screws - and here it is - the PCB!
The inner side of the battery holder has 2 contacts on it's sides
On The front we can spot
Bluetooth antenna (on the board)
Battery connectors
Murata 2x2mm RF switch connector, that can be used for RF testing
U11, U13 - probably some chips behind the shield, which is (unfortunately) firmly soldered. My guess: one of them is ultra-low power microcontroller and the other one is taking care of power delivery to the board
J1 - place for debug connector (empty in production)
On the other side
This clear place on the PCB is for the antenna on the other side
nRF52832 BLE chip (maintains the only wireless connection of this device)
This is a tiny temperature sensor (not sure which one exactly)
The metal connector is a smart way to reinforce this tiny PCB
The sensor is on the edge, but still inside plastic case, and has no thermal channel to the outside (no vents or compound) - this fact rises a huge concern about the speed of the measurements
No temperature + humidity combo here, as seen in the Thermostats... really, Nest?! I mean, for $40 I had higher expectations..
That's it. Thanks for reading! Post comments if you have any questions or suggestions
7 Comments
Good teardown report.
However, I think the orange part in Step4 should be Murata 2x2mm RF switch connector, which can be used for RF testing.
Not U.FL antenna connector, which is mainly designed to connect antenna.
Nice catch :)
I’ve updated the description, thanks!
Forest -
Please take pictures of both sides of all the components,eg front case ,back case, that’s important!thank you!
Can confirm. I have a small bedroom and I close the door when I sleep to make it darker. The result is that it can be quite a bit cooler or warmer in my bedroom than the thermostat measures. So I bought a Nest sensor. Then I woke up chilly one morning and turned the heat from 65 to 67. It was close to 75 in the bedroom before the Nest sensor thought it had hit 67.
At least the battery isn’t (strongly) thermally coupled to the board, but it doesn’t help. I bought a SensorPush Temp/humidity device which has an exposed sensor. Does an admirable job running down to -30C, but there’s a huge thermal lag (which is STILL not as bad as the Nest sensor), which I attribute to the giant coin cells mounted to the back of the sensor board.
Thanks for the Breakdown & Levi for the info. I started investigating the API and working with the sensor (I have 2 in my house) and am a bit dissapointed. documenting findings so far here if it is of interest: https://ssprod.me/blog/2022/11/14/a-clos...
