This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Muller Intuitiv Module Teardown
    1. Muller Intuitiv Module Teardown, Peel off the label: step 1, image 1 of 3 Muller Intuitiv Module Teardown, Peel off the label: step 1, image 2 of 3 Muller Intuitiv Module Teardown, Peel off the label: step 1, image 3 of 3
      • Peel off the label from the front panel
      • Heating with a hair dryer can help soften the adhesive
      • It is very difficult not to damage the sticker, which is likely designed as a tamper proof sticker
      Ask FixBot
    2. Muller Intuitiv Module Teardown, Unscrew the front panel: step 2, image 1 of 1
      • The device is closed by 2 medium Phillips screws
      • Remove the screws and it opens without difficulty
      Ask FixBot
    3. Muller Intuitiv Module Teardown, Front view of the printed circuit board: step 3, image 1 of 2 Muller Intuitiv Module Teardown, Front view of the printed circuit board: step 3, image 2 of 2
      • Microcontroller unit: STMicroelectronics STM32F412RG
      • WiFi and Bluetooth SiP module: Ampak AP6212
      • SPI flash memory: Adesto 25SF641
      • 2.4 GHz RF transceiver: Microchip (formerly Atmel) ATSAMR21E18A
      • Buck/boost: STMicroelectronics VIPER013LS
      • 3.3V LDO: OnSemi NCP1117
      Ask FixBot
    4. Muller Intuitiv Module Teardown, Rear view of the circuit board: step 4, image 1 of 2 Muller Intuitiv Module Teardown, Rear view of the circuit board: step 4, image 2 of 2
      • 4A Triac: STMicroelectronics T435
      • Triac driver optocoupler: OnSemi MOC3063M
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Eve Redero
3,354 Reputation
11 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 55
All Time: 340
