Shop the Holiday Gift Guide
This teardown is in progress – Reload periodically to see the latest changes!
Introduction
Go to step 1 ↓
  • Preparation:
    • Turn off the printer and disconnect it from the power supply or USB.
    • Prepare a small, clean workspace and a container for screws so that nothing gets lost.
  • Paper roll cover removal:
    • Gently open the cover where the paper roll is located.
    • Inspect the bottom and sides of the cover—there should be screws there.
  • Housing disassembly:
    • Using a suitable screwdriver, remove the screws from the bottom and sides.
    • Carefully remove the upper housing to avoid damaging the clips.
  • Accessing internal components:
    • After removing the housing, locate the black part (this may be the mechanism mount or another housing element).
    • Remove the screws on the black part.
  • Circuit board and battery removal:
    • Locate the screws holding the circuit board and carefully remove them.
    • Gently take out the circuit board, being mindful of the wires and ribbon cables.
    • Remove the battery (it is usually shaped like a battery).
      • I took it all apart and it works even without the casing
      Ask FixBot
Author
with
Volodymyr
73 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 41
All Time: 193
