This teardown is in progress – Reload periodically to see the latest changes!
  1. M6013 Capacitor Meter Teardown, Removing Battery: step 1, image 1 of 2 M6013 Capacitor Meter Teardown, Removing Battery: step 1, image 2 of 2
    • Remove the circled screw
    • Remove battery case and batteries
  2. M6013 Capacitor Meter Teardown, Removing Case: step 2, image 1 of 3 M6013 Capacitor Meter Teardown, Removing Case: step 2, image 2 of 3 M6013 Capacitor Meter Teardown, Removing Case: step 2, image 3 of 3
    • Remove circled screws
    • Pull case apart
    • Watch out for buttons, they will fall out easily.
  3. M6013 Capacitor Meter Teardown, Remove Circuit Board: step 3, image 1 of 3 M6013 Capacitor Meter Teardown, Remove Circuit Board: step 3, image 2 of 3 M6013 Capacitor Meter Teardown, Remove Circuit Board: step 3, image 3 of 3
    • Be careful when removing the circuit board, the battery cable is still connected.
    • Unsolder the square locations either on the circuit board or the case to fully remove the circuit board
    Good morning, community, I need help to identify the value of resistors R10, R6, R7, R1 of my m6013 that broke down by mistake.
    Ing_cor - Reply
  4. M6013 Capacitor Meter Teardown, Microprocessor: step 4, image 1 of 2 M6013 Capacitor Meter Teardown, Microprocessor: step 4, image 2 of 2
    • Location of microprocessor
  5. M6013 Capacitor Meter Teardown, Remove Display: step 5, image 1 of 2 M6013 Capacitor Meter Teardown, Remove Display: step 5, image 2 of 2
    • Remove the cable connector
    • Remove Display
Ted Hsueh
170 Reputation
3 Guides authored
Cal Poly, Team 16-56, Forte Fall 2012 Member of Cal Poly, Team 16-56, Forte Fall 2012
CPSU-FORTE-F12S16G56
5 Members
13 Guides authored
2 Comments
Add some specs on start and foto of the unit ....
Mateusz - Reply
Hello everyone, can someone help me identify the regulator that is in the printed circuit of this capacimeter identified with "U1" and the diode "D1" I appreciate any information.
CHUCHOX - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 601
