The Logitech Harmony One is a fantastic universal remote. Its well designed case, heft and button placement make it an ideal remote for a complex media setup. While the unit is well sealed against spills if you get something sticky in the buttons it will make it hard to use!
Remove the rubberized grip area by gently prying it directly away from the back starting with the end closest to the front of the remote.
Now remove the 3 remaining philips screws.
Release the tabs securing the case together by inserting a thin, rigid opening tool near the center of the remote (near the mute and back buttons) and following the gap on the front side of the remote.
Hold the charging contacts, LCD display and front cover together as you remove the backing.
Here are all the parts the the Logitech Harmony One remote
Danke für die ausführliche Anleitung. Ich musste die Tastatur reinigen, weil einige Tasten etwas klemmten und den Akku tauschen, weil er aufgebläht war und keine Kapazität mehr hatte. Mit der Anleitung und etwas Geschick kein Problem! ?
GA
17 Comments
Great guide! I wish I would have read it first before attempting to disassemble my remote to clean the buttons. Is there any way to repair where the ribbon cable contacts attach the clear plastic film on the face? It separated a little from the film and now the touch screen isn't working for the soft buttons (i.e. Current Activity, Options or Devices, etc.). Thanks!
nuukem : I had the same problem when I cleaned the buttons on my remote. I found a tip that said to gently heat the ribbon with a solder iron or heat gun. (http://www.instructables.com/id/How-to-r...) I used foil on the tip of my iron and made sure it was set before reassembling. Be patient and work slowly. Since the rest of the ribbon should be in place, it should be easy to get the contacts aligned. This worked for me. Hope it helps you. Also, my battery is swollen, so removing it after the cover is off and loosening the screw on the holder makes it easier to remove.
I have an intermittent "0". Would a little alcohol and Q tip on the metallic(?) touch pad fix the problem? I understand this model is no longer available so I want to be very careful. I prefer this model because of the large LCD screen. Thanks for the great write-up!
Sure but use at least 95%+ IPA (Isopropyl Alcohol) so no residue is left on the contacts.
mike -
This was extremely useful as I had to replace swollen batteries in two remotes. I just stopped at Step 4, removed the 4 screws from the battery holder, and removed the battery. Reassembly was easy - I found that starting at the top of the remote when snapping it back together works best..
Extremely helpful! Thanks so much. My 8 year old remote is working like new again after a quick cleaning.
Easy instruction however when I re-assembled the remote the touch screen does not respond. Is there some trick to latching the ribbon cable connector other than closing it?
Thank you for this. Made my longest lasting and most useful tech purchase feel like new once I cleaned it all up. Made what looked to be a hard product to open up extremely easy to do. Took 15mins to open, and 5 to put it back together.
Thanks for this guide. I was in trouble because the battery was bloated and it would not come out any more. There are actually some more screws just for the casing of the battery - but to get there this guide was very helpful.
Thanks for the guide. The best remote I’ve ever owned and they don’t make this one any longer. Able to get it up and running because of this guide. Kudos my friend
This works! One of my kids - no one is confessing - must have spilled coke or something sticky on the remote. The upper keypads and the volume keys were totally stuck.
Following these instructions, I was able to take the whole thing apart and clean all the keys as well as the frame with alcohol without dislodging the touch screen connector from the screen. In fact, it looks like my remote has an extra blob of adhesive where the ribbon cable attaches to the screen - maybe there were issues with early models?
Anyway, if you’re careful, you can take this apart and save your expensive remote.
Thanks ifixit!
Danke für die Anleitung. Nachdem ich vor dem Zusammenbau den Test mit dem Akku gemacht und alles funktionierte habe ich den Test wieder zusammengestellt.
Leider hat die Fernbedienung seid dem den Fehler das wenn ich sie auf den Kopf drehe geht sie aus. Wenn ich sie zurück drehe startet sie wieder.
Was kann das sein?
ist zwar etwas spät, aber ich tippe auf eine lose Flachbandleitung, evtl. ist die Verriegelung aufgegangen.
T. F. -
