This teardown is not a repair guide. To repair your Flashlight, use our service manual.
  1. LED touch light Teardown, LED touch light Teardown: step 1, image 1 of 1
    • The assembled light.
  2. LED touch light Teardown: step 2, image 1 of 1
    • Twist the mounting plate clockwise, then lift to remove it.
  3. LED touch light Teardown: step 3, image 1 of 1
    • Remove the three AAA batteries from their holders.
  4. LED touch light Teardown: step 4, image 1 of 1
    • Loosen and remove the four Phillips screws.
  5. LED touch light Teardown: step 5, image 1 of 1
    • Having removed the four Phillips screws in the previous step, separate the assembly as shown.
  6. LED touch light Teardown: step 6, image 1 of 1
    • Remove the three springs.
  7. LED touch light Teardown: step 7, image 1 of 1
    • Using the craft knife, prise and loosen the three tabs shown from their mounting points. This will make removing the battery contacts easier in the next step.
  8. LED touch light Teardown: step 8, image 1 of 1
    • Remove the battery contacts from their mounts, taking care to separate the soldered electrical wires without damaging nearby parts. Note the two smaller contacts which connect to the circuit board.
  9. LED touch light Teardown: step 9, image 1 of 1
    • Using the craft knife, slice off the black plastic extrusions at the indicated positions. These tabs secure the circuit board to the main assembly.
  10. LED touch light Teardown: step 10, image 1 of 1
    • Lift and separate the power switch from the main assembly.
  11. LED touch light Teardown: step 11, image 1 of 1
    • Using a similar technique to that exercised in step 9, slice off the clear plastic extrusions at the indicated positions. These extrusions secure the lens, case and reflector elements.
  12. LED touch light Teardown: step 12, image 1 of 1
    • The separated lens, case and reflector elements.
  13. LED touch light Teardown: step 13, image 1 of 1
    • The full assortment of separated parts.
Vimal
219 Reputation
1 Guide authored
3 Comments
LED Flashlight is the best ever app i have ever use...I love it..
Kim Pal - Reply
flashlight is very important for android user.We are providing best flashlight with different feature.You can visit flashlight with extra feature,download and enjoy it.
https://play.google.com/store/apps/detai...
flash light - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 3,650
