This teardown is not a repair guide. To repair your Keychron V3, use our service manual.
    • If you have a barebones keyboard, skip this step
    • Use the included wire keycap puller to remove the keycaps
    • Get the wire around opposite sides of the keycap, then pull straight up until it comes off
    • For keys larger than the tab key, lift from one side to release, then lift with your fingers from the center.
    • Use the included metal keyswitch puller to remove the keyswitches.
    • Do not attempt to remove the stabilizers (supports)
    • Place the keyboard upside down
    • Use the included hex key to loosen the screws on the bottom.
    • Turn back the right way up, taking care to not lose any screws in the process
    • Lift up frame around the board
    • Use the included screwdriver to remove the black screws on the pcb
    • All these screws use the same bit and same length
    • Flip PCB forward to free from the case
    • Take care of the mode-selection switch near the top of the PCB
    • This switch is fragile and will break if re-inserted incorrectly. For safety, don't toggle this switch while the PCB is removed
    • Unscrew the golden screws that are marked with wide white circles.
    • The screws with smaller/no circles are to hold in the stabilizers/stabs. Don't remove these yet
    • All the screws in this step are the same bit and same length
    • Once unscrewed, lift up the PCB away from the foam and top plate
    • Each stab is secured with a clip and a single screw, and each stab is connected to another stab with a metal rod
    • Unscrew both screws from a pair of stabs, then lift away from the tabs when removing
Someone
191 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 121
All Time: 324
