Video Overview
This teardown is not a repair guide. To repair your HomePod 2023, use our service manual.
  1. HomePod 2 Chip ID, Main Board Side 1: step 1, image 1 of 3 HomePod 2 Chip ID, Main Board Side 1: step 1, image 2 of 3 HomePod 2 Chip ID, Main Board Side 1: step 1, image 3 of 3
    • Apple APL1W86 / 339S01037 S7 64-bit dual-core applications processor layered under a SK hynix H9HA28A12MNLTR-4KJ likely 1.5 GB LPDDR4 SDRAM & 32 GB NAND Flash Memory
    • Apple 338S00325 power management
    • Probably STMicroelectronics serial EEPROM memory
    • Texas Instruments TPS62821 1 A synchronous step-down DC-DC converter
    • Texas Instruments TPS56637 6 A synchronous buck converter
    • onsemi NCP160AMX330TBG 250 mA / 3.3 V LDO regulator
    • Nexperia 74AVC1T45 voltage level translator/transceiver
  2. HomePod 2 Chip ID: step 2, image 1 of 1
    • Texas Instruments SN74AXC2T45 2-bit translating transceiver
    • Nexperia 74LVC2G125 dual bus buffer/line driver
    • Nexperia 74LVC1G08 single 2-input AND gate
  3. HomePod 2 Chip ID, Main Board Side 1 - Connectivity: step 3, image 1 of 1
    • USI 339M00243 WiFi / Bluetooth module
    • USI UWB Module
    • Possibly Qorvo QPC8019Q SPDT RF switch
    • Nordic Semiconductor nRF52820 Bluetooth 5.3 SoC
    • Skyworks SKY66404-11 2.4 GHz front-end module
  4. HomePod 2 Chip ID, Main Board Side 1 - Sensors: step 4, image 1 of 1
    • Bosch Sensortec BMA282 3-axis accelerometer
  5. HomePod 2 Chip ID, Main Board Side 2: step 5, image 1 of 2 HomePod 2 Chip ID, Main Board Side 2: step 5, image 2 of 2
    • Synaptics S3808B touch controller
    • Texas Instruments TLC5955 48-ch. LED driver
    • Knowles MEMS microphone
  6. HomePod 2 Chip ID, Main Board Side 2 - Sensors: step 6, image 1 of 1
    • Ambient light sensor
  7. HomePod 2 Chip ID, Audio Board Side 1: step 7, image 1 of 2 HomePod 2 Chip ID, Audio Board Side 1: step 7, image 2 of 2
    • Analog Devices SSM3515B audio amplifier
    • Texas Instruments PCM5242 stereo D/A converter
    • MEMS Microphones
    • Texas Instruments TLV320ADC3100 stereo A/D converter
    • Analog Devices ADAU7002 stereo PDM–to-I2S or TDM converter
    • Texas Instruments TPS54560B 5 A step-down DC-DC converter
    • Texas Instruments INA210A ? current sense amplifier
  8. HomePod 2 Chip ID: step 8, image 1 of 1
  9. HomePod 2 Chip ID, Audio Board Side 2: step 9, image 1 of 2 HomePod 2 Chip ID, Audio Board Side 2: step 9, image 2 of 2
    • Texas Instruments TAS3255C audio amplifier
    • Texas Instruments TLV320ADC3100 stereo audio A/D converter
    • Texas Instruments TLA2528 8-Ch, 12-Bit A/D Converter
    • MEMS Microphone
    • Texas Instruments INA253A1 current sense amplifier
  10. HomePod 2 Chip ID: step 10, image 1 of 1
    • Renesas mixed signal array
    • onsemi NCP160AMX180TBG 250 mA / 1.8 V LDO regulator
    • Texas Instruments TLV70733P 200 mA / 3.3 V LDO regulator
    • Texas Instruments TLV70736P 200 mA / 3.6 V LDO regulator
    • Texas Instruments SN74AUP1G74 single D-Type Flip-Flop
    • Nexperia 74LVC1G07 single buffer
  11. HomePod 2 Chip ID: step 11, image 1 of 1
  12. HomePod 2 Chip ID, Power Supply Board Side 1: step 12, image 1 of 2 HomePod 2 Chip ID, Power Supply Board Side 1: step 12, image 2 of 2
  13. HomePod 2 Chip ID, Power Supply Board Side 2: step 13, image 1 of 2 HomePod 2 Chip ID, Power Supply Board Side 2: step 13, image 2 of 2
  14. HomePod 2 Chip ID, Sensor Flex: step 14, image 1 of 1
    • Texas Instruments HDC2010 Humidity & Temperature Sensor
One Comment
Have you guys given up on Galaxy devices?
djlobb01 - Reply
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 83
All Time: 2,352
