This teardown is not a repair guide. To repair your HP Windows Mixed Reality Headset VR1000-100, use our service manual.
  1. HP Windows Mixed Reality Headset Developer Edition Teardown, HP Windows MR HMD Teardown: step 1, image 1 of 2 HP Windows Mixed Reality Headset Developer Edition Teardown, HP Windows MR HMD Teardown: step 1, image 2 of 2
    • HMD Specs:
    • Two high-resolution liquid crystal displays at 1440 x 1440
    • 2.89” diagonal display size (x2)
    • Front hinged display
    • Double padded headband and adjustment knob
    • Built-in audio out and microphone support through 3.5mm jack
    • Single 4.00m/0.60m removable cable with HDMI 2.0 (display) and USB 3.0 (data) for connectivity
  2. HP Windows Mixed Reality Headset Developer Edition Teardown, Remove eye-rings, foam padding, and outer shell: step 2, image 1 of 3 HP Windows Mixed Reality Headset Developer Edition Teardown, Remove eye-rings, foam padding, and outer shell: step 2, image 2 of 3 HP Windows Mixed Reality Headset Developer Edition Teardown, Remove eye-rings, foam padding, and outer shell: step 2, image 3 of 3
    • Remove the foam protector from the velcro-type adhesive strip.
    • Remove the two eye-rings with a flat head screwdriver.
    • Also with a flat head screwdriver, carefully pry apart the outer plastic shell from the HMD
  3. HP Windows Mixed Reality Headset Developer Edition Teardown, Remove interior plastic and screws: step 3, image 1 of 3 HP Windows Mixed Reality Headset Developer Edition Teardown, Remove interior plastic and screws: step 3, image 2 of 3 HP Windows Mixed Reality Headset Developer Edition Teardown, Remove interior plastic and screws: step 3, image 3 of 3
    • To remove the next layer of protective plastic, you'll need to remove 16 screws
    • 1 on each side
    • and 14 on the front
  4. HP Windows Mixed Reality Headset Developer Edition Teardown, Remove head-strap, plastic casing and cable clip: step 4, image 1 of 2 HP Windows Mixed Reality Headset Developer Edition Teardown, Remove head-strap, plastic casing and cable clip: step 4, image 2 of 2
    • Now that the screws are removed, the next plastic layer can be removed.
    • The cable will still be connected to the adjustable head strap. This can be removed easily by prying it off with a flathead screwdriver
  5. HP Windows Mixed Reality Headset Developer Edition Teardown, Remove 3.5mm headphone jack: step 5, image 1 of 3 HP Windows Mixed Reality Headset Developer Edition Teardown, Remove 3.5mm headphone jack: step 5, image 2 of 3 HP Windows Mixed Reality Headset Developer Edition Teardown, Remove 3.5mm headphone jack: step 5, image 3 of 3
    • In the bottom left corner of the HMD, you'll find the audio jack and the board attached to it.
    • With a flat head screwdriver, gently pry the connector from the headphone jack board. Once the board has been disconnected, it will fall right out.
  6. HP Windows Mixed Reality Headset Developer Edition Teardown, Separate the lenses from the PCB: step 6, image 1 of 3 HP Windows Mixed Reality Headset Developer Edition Teardown, Separate the lenses from the PCB: step 6, image 2 of 3 HP Windows Mixed Reality Headset Developer Edition Teardown, Separate the lenses from the PCB: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Remove four more screws. The bottom left screw will release the audio board support.
    • Peel back the lenses at a 45° angle from the bottom up.
    • You'll then see two yellow strips held with black protective tape. Peel back the tape with tweezers.
    • Also with tweezers, remove the yellow tape over the connection between the PCB and the lenses.
    • The lenses appear to be fresnel on the inside but smooth on the outside.
  7. HP Windows Mixed Reality Headset Developer Edition Teardown, Remove metallic tape: step 7, image 1 of 3 HP Windows Mixed Reality Headset Developer Edition Teardown, Remove metallic tape: step 7, image 2 of 3 HP Windows Mixed Reality Headset Developer Edition Teardown, Remove metallic tape: step 7, image 3 of 3
    • With the lenses removed, you can begin separating the PCB from whats left of the HMD.
    • USE TWEEZERS to peel back the two pieces of metallic tape on the PCB (this tape is SHARP — do not use your hands).
    • Remove the four screws to remove the two metal clips on each side of the PCB.
  8. HP Windows Mixed Reality Headset Developer Edition Teardown: step 8, image 1 of 3 HP Windows Mixed Reality Headset Developer Edition Teardown: step 8, image 2 of 3 HP Windows Mixed Reality Headset Developer Edition Teardown: step 8, image 3 of 3
    • After removed the PCB, you can see the front camera sensor compartment.
    • Peel off the copper tape on both side before the next step. (SHARP EDGES -TWEEZERS recommend).
    • Remove 4 screws to disassemble the front camera sensor on each side.
    • Cameras were not easily identifiable, however, they looked identical to the cameras we found in our Acer MR HMD teardown. Also had similar part numbers to the the Microsoft Surface 3 rear camera.
  9. HP Windows Mixed Reality Headset Developer Edition Teardown, Separate metal and cable from PCB: step 9, image 1 of 3 HP Windows Mixed Reality Headset Developer Edition Teardown, Separate metal and cable from PCB: step 9, image 2 of 3 HP Windows Mixed Reality Headset Developer Edition Teardown, Separate metal and cable from PCB: step 9, image 3 of 3
    • The metal cover to the PCB can be easily pried apart with a flat head screwdriver.
    • After doing this, the two screws connecting the cable to the PCB is revealed.
    • Remove the two screws, then pop off the connector straight up, not at an angle.
  10. HP Windows Mixed Reality Headset Developer Edition Teardown, PCB and Components: step 10, image 1 of 2 HP Windows Mixed Reality Headset Developer Edition Teardown, PCB and Components: step 10, image 2 of 2
  11. HP Windows Mixed Reality Headset Developer Edition Teardown, Cabling: step 11, image 1 of 3 HP Windows Mixed Reality Headset Developer Edition Teardown, Cabling: step 11, image 2 of 3 HP Windows Mixed Reality Headset Developer Edition Teardown, Cabling: step 11, image 3 of 3
    • The main cable is a USB and HDMI to a proprietary connector.
    • Instead of plugging directly into the HMD, the proprietary connector plugs into a receptacle which is attached to an embedded connector (shown on the PCB in steps nine and ten).
  12. HP Windows Mixed Reality Headset Developer Edition Teardown, Active cable module: step 12, image 1 of 3 HP Windows Mixed Reality Headset Developer Edition Teardown, Active cable module: step 12, image 2 of 3 HP Windows Mixed Reality Headset Developer Edition Teardown, Active cable module: step 12, image 3 of 3
    • After finding an active cable module within the Acer headset, we were curious as to why the HP headset had no chips on their cable. So we opened up the proprietary connector on the cable (Do not do this. You won't be able to easily put it back together)
    • Under the plastic shell, we found a similar Spectra7 cable module similar to that of the Acer Windows HMD
    • Spectra7 VR8050 USB 3.0 Cable Equalizer
    • Spectra7 HT8181 HDMI 2.0 Cable Equalizer
Super_All_In_One
201 Reputation
2 Guides authored
19 Guide Comments
This is fantastic thank you! Any plans on tearing down the other four MR headsets from Microsoft?
Connor Dolan - Reply
Hi there,
I am wondering if anyone knows the components I have highlighted.
[IMG]http://i63.tinypic.com/2hxsz1f.jpg[/IMG]
[IMG]http://i66.tinypic.com/2mm5zyu.jpg[/IMG]
[IMG]http://i63.tinypic.com/33w8hop.jpg[/IMG]
My HP WMR unit had a power surge and has burnt out most of these components.
A good electrical engineer friend of mine has cast a close eye over all the other components on the board, showing no physical damage (which I know doesn’t mean that they all ok).
I live in hope that I will be able to repair my WMR headset, as I have myself had plenty of experience with SM components.
Just identifying the values of these components is proving to be mighty tricky!
I believe (A) 6 pin “EDVGA” are voltage regulators - SOT23-6?
(B) Transistor? - “NA ID9” ?
Appreciate any help :)
Paul
Paul Slater - Reply
Any info on the sensor in the center mounted between the lenses?
Frank McCown - Reply
From what i’ve seen on other headsets it’s a light sensor ..
controls brightness during light bleed.
Timothy Bartlett - Reply
Hi. My cameras stopped working, and I think it's because of the USB cable damage.
Do usb3. 0 sstx ssrx lines conduct current when there's no power on hdmi & USB equalizers? I'm sticking one probe of the multimeter to the USB's sstx and the other one to every pin of the combined HDMI-USB plug.
USB 2.0's lines conduct current just fine, but usb 3's line are quiet.
Thanks.
PainSandwich - Reply
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 103
All Time: 17,332
