Once the screws are removed use the spudger on either side of the charge port, pop the clips open then you can work your way around to the other side of the body, although it will probably pop the rest of the way open once you unhook those clips.
Once you have the device open and the screen disconnected, use the T6 driver again and remove these two screws holding the lanyard anchor in place, then you can carefully lift the motherboard out of its place.
Thx solved my issue because i didnt remember where the red/black cable was and the camery module didnt have proper pressure from the clamps also i had to search 2h for a replacement battery… (for anyone wondering model number is 523450 and i used one from Varta)
