This teardown is not a repair guide. To repair your Dual USB Connector, use our service manual.
  1. MSI Dual USB Port Bracket Teardown, MSI Dual USB Port Bracket Teardown: step 1, image 1 of 1
    • This part of the bracket consists of the circuit board enclosed in a plastic housing, which we will tear down in the next step.
    • These connectors plug into the USB headers on the motherboard.
  2. MSI Dual USB Port Bracket Teardown: step 2, image 1 of 2 MSI Dual USB Port Bracket Teardown: step 2, image 2 of 2
    Tool used on this step:
    Phillips #1 Screwdriver
    $5.49
    Buy
    • Use a Phillips #1 screwdriver to remove the four screws from the white casing and the two screws from the metal bracket.
    • On the bottom of the circuit board, the pins that hold its components can cut skin.
    • The two USB 2.0 ports.
    • The four LED lights, which light up depending on the activity of the USB ports.
  3. MSI Dual USB Port Bracket Teardown: step 3, image 1 of 1
    • Raise the three connectors from the case and it's out!
    • The connectors highlighted in red lead to the wires that connect the bracket to the motherboard.
    • The two USB ports.
    • The LED activity lights.
samhnri
415 Reputation
2 Guides authored
One Comment
Why does it need its owe usb header just for the LED's.
Rick Acker - Reply
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 54
All Time: 7,820
