Introduction
This server was developed for quick and easy disassembly, but not in all components
Featured Document
Press the two green tabs and pull up the fan on the CPUs.
To remove the second fan you have to pull the green tab and pull the fan up.
Press down and at the same time move the two green tabs in (in orange).
Lift the heat sink.
Repeat the procedure to open the socket.
To remove a RAM bank you have to press hard on the white clips.
Repeat the procedure for all desks.
Pull out the 3 green tabs (in orange) and open slowly as if it were a door.
Unscrew the three screws as shown in the photo.
Disconnect and the cables and pull out the front of the caddy.
Unscrew the screw inside the case and the screws placed on the outside.
The external screws (in blue) secure the power supply to its caddy and are to be removed once out of the case.
Slide the power supply inward and pull it out.
Special thanks to these translators:
100%
Marc developer is helping us fix the world! Want to contribute?
Start translating ›
