Introduction
This fine computing device was recently discovered in an undisclosed warehouse where it was being studied by Top... Men.
What could be lurking inside this heavy metal box? A Golden Idol... The Ark of the Covenant... Giant Ants?
These are all possibilities, but there's only one way to find out for sure.
Behold, the power of beige!
Tech Specs:
933 MHz Pentium III Processor
10 GB PATA Hard Disk
512 MB of PC133 RAM
16x DVD-ROM and 3.5" Floppy Drive
Life Experience
Some of these ports belong in a museum:
RS-232 Serial
DB-25 Parallel
PS/2
DE-15 VGA (oh, wait...)
The antenna is a pretty big clue that this computer has been upgraded at some point.
The various drives are mounted on a single hinge that flips forward. Just pull up and it will click into place.
The PCI riser is one of the few things missing a green label. The release button is the silver tab towards the front of the computer.
The power supply swivels up and away from the motherboard.
The first step in removing the CPU cooler is to unplug the small three pin power cable.
The CPU cooler is attached to the socket with metal hooks. Removing it without damaging the CPU requires two distinct motions:
Gently push down on the red tab.
Squeeze the red tab towards the fan and then lift the cooler.
Umm… On the orange point; You say to push the red tab towards the fan, but the orange arrow in the image points away from it…
Which is it? - I’m trying to remove it, but I’ve tried both ways and I don’t dare to push or bend much more.
Also, the tab seems to suggest that you should indeed "squeeze” it inwards, with it having the ribbed concave texture there.
I can’t seem to figure out how it goes visually…
Tool used on this step:Anti-Static Wrist Strap$7.95
Removing the CPU requires a steady hand and can be slightly intimidating.
A beige lever keeps the CPU locked in place. Pull it away from the processor and then up. The processor will move towards the group of capacitors when it is unlocked.
The processor can be removed from the socket by gripping the edges and pulling straight up.
That's it. Now we just need to reassemble it before someone realizes it's not in the warehouse.
Completely Unofficial Compaq Deskpro EN Repairability Score: 10 out of 10 (10 is easiest to repair)
It practically tells you how to disassemble it.
Most common repairs can be done with one tool.
Faces remain unmelted after removing the cover. (Always a good thing.)
Finding replacement parts may require entering a Temple of Doom/RadioShack.
5 Comments
Personally I’d include ease of finding suitable replacement parts in a reparability score, I’ve worked on these things and would rate them at 8.5-9.5 for non-standard motherboard, motherboard mountings, and power supply.
If purchasing rather than leasing, I think the point was retire the first few that break out of warranty, and start parting them out. Compaq was very good about keeping the same line going for a long time so the parts would be compatible.
Awesome! I love these machines. I’m pretty sure these ones will run a Tualatin PIII if you upgrade the BIOS too.
do you know, how to oil noisy power supply fan in this computer? I tried but I can’t open it?
Thanks for the quality
this writing style is funny
