This teardown is not a repair guide. To repair your Brother P-Touch TZe Tape 12mm, use our service manual.
  1. Brother P-Touch TZe Tape 12mm Teardown, Cartridge Overview: step 1, image 1 of 1
    • Insert wisdom here.
  2. Brother P-Touch TZe Tape 12mm Teardown, Tape Flow: step 2, image 1 of 1
    • Top clear tape
    • Thermal ink tape
    • White backing with adhesive
    • Thermal printer zone
  3. Brother P-Touch TZe Tape 12mm Teardown, Printing Process: step 3, image 1 of 3 Brother P-Touch TZe Tape 12mm Teardown, Printing Process: step 3, image 2 of 3 Brother P-Touch TZe Tape 12mm Teardown, Printing Process: step 3, image 3 of 3
    • The clear top tape (light blue line) is usually completely clear.
    • The tape is empty and the zebra stripes indicates it to the user.
    • The thermal ink tape gets unrolled and again rolled onto another roller.
    • In the printing zone, a single column of heat "pixels" heats the thermal ink (red line) and sticks it to the clear top tape (blue line).
    • The clear top tape than gets laminated with the white backing (white line).
  4. Brother P-Touch TZe Tape 12mm Teardown, Inverted Image on Ink Tape: step 4, image 1 of 1
    • Since the ink from the printed spots is now on the label and not longer on the ink tape, you can see a inverted image of everything the cartridge ever printed.
    • Keep that in mind when printing sensitive information like passwords or PPI!
  5. Brother P-Touch TZe Tape 12mm Teardown, Resolution: step 5, image 1 of 2 Brother P-Touch TZe Tape 12mm Teardown, Resolution: step 5, image 2 of 2
    • The resolution of the text font seems to be lower than the icons (this icon should resemble a old mobile phone).
    • The small dots on the mobile phone are about 180 µm apart.
    • Both images are captured using the same magnification. The image circle has a diameter of approximately 2.5 mm.
Quanten
1,003 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 105
All Time: 105
