Introduction
This teardown is done as to comply with task 2 IDES 2072, 2020. Photographed and written by Angelo Diaz, James Rosenberg, Jaya Yoannidis and Ewan Mackay-Cruise. Second year students of Bachelor of Industrial Design UNSW Sydney, Australia.
Once removing the screws, partially seperate the body from the white casing.
As shown, there are 4 screws that have to be removed to fully seperate the 2 parts.
Use a phillips screwdriver to unscrew the screws.
Flip the toaster on the other side and pull the highlighted wire to detach it from the bottom part.
You can now seperate the parts to give 2 seperate parts. (The white casing and the electrical body).
Although the plastic casing of the transformer has been detached there is still a small piece of plastic holding down the connected wires of the transformer.
This can be removed by unscrewing both screws displayed in the images.
Once this piece of plastic is no longer bond by screws you are able to completely detach the transformer by pulling the wires out from inside the toaster.
The plastic parts should easily come off, however they are still attached to wires and are soldered on. They lead into the main chassis.
The next step is to remove any wiring leading into the chassis.
Be careful not to pull too hard on the pieces as there may be wires on the inside attached.
Now that the latch is open you can remove the final wire attached to the plastic part. This concludes the teardown of removable parts within the toaster.
Note: Removing other remaining parts may alter the function of the toaster as they are permanently joined.
You have now completed the teardown.
