Introduction
The Breville Induction Cooker (LIC400BLK ANZ) is an efficient cooktop that uses induction cooking to quickly heat your cookware.
Once you have your Breville Induction Cooker. You will notice the body is made up of an injection moulded ABS base and ceramic glass panel top. Let's take a closer look at the features on the top;
A power Button
Time Control
8 Cooking modes; sear, saute, medium, simmer, water boil, steam, slow cook, and, milk.
A child Lock
A keep warm
A saucepan detecting area
Now let's tear it down. Use a Phillips head screwdriver to undo the 6 screws found on the fringe of the back face. There are also 2 triangular screws located in the middle to be unscrewed (8 screws in total). Carefully flip the cooker so that the ceramic panel faces the top, then lift the panel to remove it from the case.
Philips dome head screw x6 - M4x8mm
Triangle dome head screw x2 - M4x10mm
Once open, you can locate the User Interface PCB (Printed Circuit Board). On this we can see;
The timer
Sensor buttons
LED display
Resistors
Capacitors
To remove the user PCB, use the Philips head screwdriver to undo the 8 screws securing it to the base. Unclip the white wires that attach to the Main PCB before lifting the board out.
Phillips round head screw x8 - M3x6mm
Next locate the copper induction coil, which uses alternating current to create a magnetic field. Thus, creating heat by inducing a current.
Use the Phillips head screwdriver, to undo the 3 screws holding the induction coil to the base. Remove each screw and their respective washers. Then lift it out and place beside the base.
Dual Phillips/slotted round head screw x3 - M4x12mm
Washers x3 - inner Ø 4mm, outer Ø 16mm
To the right of the circuit is the Main PCB which powers the internal components. On this we can see;
The AC power plugs
Capacitors
Resistors
Microprocessors
A fuse
A heat sink
Inductors
To remove, use the Phillips head screwdriver to undo the 4 screws securing it to the base. Then gently pop all the chords out of the fasteners on the PCB. Once both the Induction coil and the Main PCB have been unscrewed, remove both.
Phillips round head screw x4 - M3x6mm
The aluminium heat sink, as we identified in Step 5 is a passive cooling device meaning it involves no electronics. The ribs provide surface area to allow air flow from the fan to help cool the inner components.
To remove, flip the Main PCB upside down and use a Phillips head screwdriver to undo the 4 screws around the heat sink. Then lift from PCB
Phillips washer head screw x2 - M3x10mm
Phillips washer head screw x2 - M3x16mm
In the centre of the coil there are two sensors, a temperature sensor and an electromagnetic wave sensor. Attached to the ceramic glass plate via the thermal paste.
Carefully push the sensors rubber casing out of the induction coil.
Going back to the base locate the ABS fan, which cools the electrical components.
Use the Phillips head screwdriver to undo the 2 screws. Remove each screw and their respective washers before lifting the fan from the base.
Plastic washers x2 - inner Ø4mm, outer Ø10mm
Phillips washer head screws x2 - M3x8mm
Finally, where the induction coil was, there is a circular aluminium shield attached to the base. The shield prevents energy from the induction coil escaping downward.
To remove simply use the Philips head screwdriver to undo the screw located at the centre. Lift the shield to remove it from the base.
Phillips dome head screw x1 - M3x6mm
Only a Phillips head and triangular head screwdriver are needed for the teardown.
The Induction Cooker only has a few subassemblies that are easy to remove.
Easy to understand when opened as the subassemblies are laid out well.
The need of a triangular screwdriver may require purchasing extra equipment.
Thermal paste on a lot of the parts makes working a safety hazard.
This induction cooker is not the most recent version, thus replacement of parts may be scarce.
7 Comments
my Severin 2 induction plates will not heat any longer. All the touch pads are working fine but no heat is produced on either plate. I noticed that the heat sink paste on both plates is damaged and has come off. Could that be the reason? Can I use any heat sink paste ? Thanks for your help
usha inducation 2000 wat quwil
What kind of thermal paste I should use?
My induction cooker name is pegon last night I'm going to use cooker is dead not on so which problem I can't understand how can solve this pls help
