This teardown is in progress – Reload periodically to see the latest changes!
  1. Bosch GST90BE Jigsaw Disassembly, Diagnosis: step 1, image 1 of 1
    • This is the Bosch gst90be, a hand held Jigsaw from the Bosch Pro range.
    • This guide will show you how to disassemble it to make repairs.
  2. Bosch GST90BE Jigsaw Disassembly, Removing base shoe: step 2, image 1 of 2 Bosch GST90BE Jigsaw Disassembly, Removing base shoe: step 2, image 2 of 2
    • Undo and remove 5mm Hex screw and square washer from Shoe, and remove shoe.
  3. Bosch GST90BE Jigsaw Disassembly, Remove blade lever: step 3, image 1 of 2 Bosch GST90BE Jigsaw Disassembly, Remove blade lever: step 3, image 2 of 2
    • Remove 1 T20 Torx screw and washer from blade lever, then remove blade lever and spring.
  4. Bosch GST90BE Jigsaw Disassembly, Remove metal cover and wire blade guard: step 4, image 1 of 3 Bosch GST90BE Jigsaw Disassembly, Remove metal cover and wire blade guard: step 4, image 2 of 3 Bosch GST90BE Jigsaw Disassembly, Remove metal cover and wire blade guard: step 4, image 3 of 3
    • Remove 2 Posidriv screws from front cover, then slide off front cover and remove wire blade guard, which rests in a recess behind the metal cover.
    • Remove one Torx T20 screw
  5. Bosch GST90BE Jigsaw Disassembly, Disassembly: step 5, image 1 of 1
    • Remove eight T20 Torx screws from the body of the saw. (The ninth screw was under the silver metal cover).
  6. Bosch GST90BE Jigsaw Disassembly, Separate casing: step 6, image 1 of 1
    • You can now separate the two halves of the saw, which allows you to access all of the components
    • To reassemble the saw, follow the instructions in this guide in reverse order.
Leo Maxwell
855 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 503
