Video Overview
This teardown is not a repair guide. To repair your BlackBerry porsche design P'9981, use our service manual.
  1. BlackBerry porsche design P'9981 Teardown, BlackBerry porsche design P'9981 Teardown: step 1, image 1 of 3 BlackBerry porsche design P'9981 Teardown, BlackBerry porsche design P'9981 Teardown: step 1, image 2 of 3 BlackBerry porsche design P'9981 Teardown, BlackBerry porsche design P'9981 Teardown: step 1, image 3 of 3
    • turn off ur porsche design P'9981
  2. BlackBerry porsche design P'9981 Teardown: step 2, image 1 of 3 BlackBerry porsche design P'9981 Teardown: step 2, image 2 of 3 BlackBerry porsche design P'9981 Teardown: step 2, image 3 of 3
    • remove back cover ... then unscrew 6 screws
  3. BlackBerry porsche design P'9981 Teardown: step 3, image 1 of 3 BlackBerry porsche design P'9981 Teardown: step 3, image 2 of 3 BlackBerry porsche design P'9981 Teardown: step 3, image 3 of 3
    • remove the back plastic plate
  4. BlackBerry porsche design P'9981 Teardown: step 4, image 1 of 3 BlackBerry porsche design P'9981 Teardown: step 4, image 2 of 3 BlackBerry porsche design P'9981 Teardown: step 4, image 3 of 3
    • remove the keyboard Connector carefully
  5. BlackBerry porsche design P'9981 Teardown: step 5, image 1 of 3 BlackBerry porsche design P'9981 Teardown: step 5, image 2 of 3 BlackBerry porsche design P'9981 Teardown: step 5, image 3 of 3
    • remove the security clasp so u can pull out the screen's ribbon cable carefully
  6. BlackBerry porsche design P'9981 Teardown: step 6, image 1 of 3 BlackBerry porsche design P'9981 Teardown: step 6, image 2 of 3 BlackBerry porsche design P'9981 Teardown: step 6, image 3 of 3
    • carefully pull out the screen's ribbon cable
  7. BlackBerry porsche design P'9981 Teardown: step 7, image 1 of 3 BlackBerry porsche design P'9981 Teardown: step 7, image 2 of 3 BlackBerry porsche design P'9981 Teardown: step 7, image 3 of 3
    • carefully remove the connector of screen keys ribbon cable
  8. BlackBerry porsche design P'9981 Teardown: step 8, image 1 of 3 BlackBerry porsche design P'9981 Teardown: step 8, image 2 of 3 BlackBerry porsche design P'9981 Teardown: step 8, image 3 of 3
    • carefully push the screen out from the back to the front
  9. BlackBerry porsche design P'9981 Teardown: step 9, image 1 of 3 BlackBerry porsche design P'9981 Teardown: step 9, image 2 of 3 BlackBerry porsche design P'9981 Teardown: step 9, image 3 of 3
    • now the screen is out of the metal chassis
    • insert your metal blade tool carefully between the screen's chassis and the on screen keys to remove it's panel
  10. BlackBerry porsche design P'9981 Teardown: step 10, image 1 of 3 BlackBerry porsche design P'9981 Teardown: step 10, image 2 of 3 BlackBerry porsche design P'9981 Teardown: step 10, image 3 of 3
    • now the keys coming out
  11. BlackBerry porsche design P'9981 Teardown: step 11, image 1 of 3 BlackBerry porsche design P'9981 Teardown: step 11, image 2 of 3 BlackBerry porsche design P'9981 Teardown: step 11, image 3 of 3
    • insert your metal blade tool carefully to remove the plastic bottom piece
  12. BlackBerry porsche design P'9981 Teardown: step 12, image 1 of 3 BlackBerry porsche design P'9981 Teardown: step 12, image 2 of 3 BlackBerry porsche design P'9981 Teardown: step 12, image 3 of 3
    • take it out .. don't worry its glued so u have to pull it out but (carefully)
    • now remove the small ear piece
  13. BlackBerry porsche design P'9981 Teardown: step 13, image 1 of 3 BlackBerry porsche design P'9981 Teardown: step 13, image 2 of 3 BlackBerry porsche design P'9981 Teardown: step 13, image 3 of 3
    • now u have to remove the keyboard panel .. from left side insert your metal blade tool between the panel and the metal chassis .. so it can pull out
  14. BlackBerry porsche design P'9981 Teardown: step 14, image 1 of 3 BlackBerry porsche design P'9981 Teardown: step 14, image 2 of 3 BlackBerry porsche design P'9981 Teardown: step 14, image 3 of 3
Mostafa Mohammed
41 Reputation
1 Guide authored
One Comment
Hello Mostafa,
Thanks for the clear teardown! If you would grade this phone on repairability, according to the iFixit's grading system, what grade would it be and why? (Repairability)
Regards, Guus
Guus van Bohemen - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 2,250
