This teardown is not a repair guide. To repair your Binbok EVO Pro Controller, use our service manual.
  1. Binbok EVO Pro Controller Teardown, Remove six screws from the back.: step 1, image 1 of 3 Binbok EVO Pro Controller Teardown, Remove six screws from the back.: step 1, image 2 of 3 Binbok EVO Pro Controller Teardown, Remove six screws from the back.: step 1, image 3 of 3
    • Use a Phillips #0 screwdriver.
  2. Binbok EVO Pro Controller Teardown, Lift the back cover off.: step 2, image 1 of 1
    • The cover pulls off without much resistance.
  3. Binbok EVO Pro Controller Teardown, Unplug the battery and the rumble motors.: step 3, image 1 of 1
    • Peel the battery up carefully. The adhesive is sticky and lifts easily off the PCB. I was a bit worried about being able to put the battery back, but the adhesive is sufficiently sticky to re-install it.
  4. Binbok EVO Pro Controller Teardown, Remove six screws from the PCB.: step 4, image 1 of 1
    • Four screws are near the middle of the PCB while two screws are hidden away near the motors.
  5. Binbok EVO Pro Controller Teardown, Lift the PCB out.: step 5, image 1 of 1
    • Insert wisdom here.
  6. Binbok EVO Pro Controller Teardown, Pull the silicone button covers out.: step 6, image 1 of 2 Binbok EVO Pro Controller Teardown, Pull the silicone button covers out.: step 6, image 2 of 2
    • The covers each have little inserts that can be pulled through with tweezers or pliers when re-installing them.
  7. Binbok EVO Pro Controller Teardown, ALPS joysticks.: step 7, image 1 of 1
  8. Binbok EVO Pro Controller Teardown, All the parts.: step 8, image 1 of 1
  9. Binbok EVO Pro Controller Teardown, It works!: step 9, image 1 of 1
    • I put the controller back together and it still works!
Tim McMahon
16 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 19
Past 30 Days: 109
All Time: 109
