BUMM IQ-XS Bike Front Light Busch & Müller Teardown
  1. BUMM IQ-XS Bike Front Light Busch & Müller Teardown, Removing the mount and front lens: step 1, image 1 of 2 BUMM IQ-XS Bike Front Light Busch & Müller Teardown, Removing the mount and front lens: step 1, image 2 of 2
    • The aluminium housing is made from one piece, so access to the inside is only by removing the front lens.
    • The chassis is held to the aluminium housing by the same T15 torx screw that also holds the mount in place. Remove this screw first.
  2. BUMM IQ-XS Bike Front Light Busch & Müller Teardown, Removing the front lens: step 2, image 1 of 2 BUMM IQ-XS Bike Front Light Busch & Müller Teardown, Removing the front lens: step 2, image 2 of 2
    • The lens is held in place only by the two notches to the left and right. They are wedge-shaped in profile.
    • The visible black ring is a thin layer of rubber and acts as water sealant. It doesn't contribute importantly to fixation of the lens, may be damaged though during disassembly.
    • Start removing the lens on one side. The other side will come out by itself without more prying. Us a narrow and flat spatula on one side of the housing to guide the lens notch out of the slit in the aluminium housing.
    • You may need a second spatula to push against the notch from through the slit.
  3. BUMM IQ-XS Bike Front Light Busch & Müller Teardown: step 3, image 1 of 1
    • Gently pull out the entire interior to the front. The LED circuit board is attached to another aluminium heat sink plate. This is not attached to the main aluminium housing though and just slides out together with the LED circuit board.
    • Complete steps in reverse order to reassemble.
    • Of note: The main circuit board has three holes that center it on the 3 plastic suspensions of the main chassis. Take care to align those properly (consider using a drop of glue on each of the suspension pins to keep it in place).
    • If they don't align, the LED circuit board will stick out 1mm in the front, preventing the lens from snapping in place properly. This will result in a gap between rubber ring and housing, where water may leak in.
    • I recommend UHU Por styrofoam glue for this purpose, as it doesn't damage the plastic or circuit board and remains flexible as it dries up.
    • Same method may be used to hold the silicone back cover in place during reassembly.
    • Good luck!
5 other people completed this guide.
Martin Kuklinski
930 Reputation
4 Guides authored
7 Comments
Thank you Martin for the instructions! Without instructions I would have had to buy a new light, one of the cables was broken.
When reassembling, I initially left out the silicone back cover. This enabled me to push the circuit board against the reflector through the hole at the back and thread everything in without any problems. Then I screwed in the screw of the bracket at the bottom (T15 torx screw) again so that the inner workings were fixed. Then I was able to install the silicone back cover at the back and finally push the lens back in at the front. I didn't need glue.
Nielsson - Reply
Thank you Nielsson for that alternative!
Martin Kuklinski -
Thank you for posting your experience with disassembly of the IQ-X. While you had it open, did you notice if it there is a simple way to bypass the Senso mode?
Lawrence Breen - Reply
Sorry, I didn’t look at the circuits that closely. If you found a way feel free to share it here!
Martin Kuklinski -
Thank you Martin was able to fix my light just a rear cable broken
alastair - Reply
Past 24 Hours: 18
Past 7 Days: 67
Past 30 Days: 271
All Time: 8,521
