Introduction
Go to step 1 ↓
This CD-Radio had a broken CD player, so I decided to take it apart.
Tools
This teardown is not a repair guide. To repair your CD Player, use our service manual.
    1. Audiovox CD-Radio Teardown, Audiovox CD-Radio Teardown: step 1, image 1 of 3 Audiovox CD-Radio Teardown, Audiovox CD-Radio Teardown: step 1, image 2 of 3 Audiovox CD-Radio Teardown, Audiovox CD-Radio Teardown: step 1, image 3 of 3
      • Here it is, ready to be torn'd!
      Ask FixBot
    2. Audiovox CD-Radio Teardown: step 2, image 1 of 3 Audiovox CD-Radio Teardown: step 2, image 2 of 3 Audiovox CD-Radio Teardown: step 2, image 3 of 3
      • Pop off the battery cover and remove the 6 C batteries. Keep them though, they might still be good.
      • Unscrew the 4 highly visible screws with the medium size screwdriver.
      • You'll need a longer bit or a different screwdriver for the other 3 holes. I attempted to unscrew it with my bit based driver, but was unsuccessful.
      Ask FixBot
    3. Audiovox CD-Radio Teardown: step 3, image 1 of 3 Audiovox CD-Radio Teardown: step 3, image 2 of 3 Audiovox CD-Radio Teardown: step 3, image 3 of 3
      • Work your way around the edge shown here with your fingers until a crack appears. Then it should be easy to lift the bottom off.
      • Be careful, The bottom is attached by a few wires. I nearly ripped these apart as I removed the bottom of the case.
      Ask FixBot
    4. Audiovox CD-Radio Teardown: step 4, image 1 of 3 Audiovox CD-Radio Teardown: step 4, image 2 of 3 Audiovox CD-Radio Teardown: step 4, image 3 of 3
      • Now, hunt down all the little screws on the motherboard and remove them. There are 4 or 5, so if it doesn't want to move, it's probably being held by a screw or two.
      • Now that all the screws, are gone, slowly lift and remove the motherboard. I say slowly because there are still a few cables attatched to the underside.
      • Disconnect all cables that aren't soldered on.
      Ask FixBot
    5. Audiovox CD-Radio Teardown: step 5, image 1 of 3 Audiovox CD-Radio Teardown: step 5, image 2 of 3 Audiovox CD-Radio Teardown: step 5, image 3 of 3
      • Now that those cables are removed, lift the motherboard up and out... or not.
      • The motherboard is attached to the LCD board via one of those pesky ribbon cables that's soldered on both ends and always seems to be covered in some sticky substance.
      • Lift the motherboard up so you have a good view of the LCD board.
      Ask FixBot
platnicat
44 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 74
All Time: 2,158
