Turn the device upside down so that the information printed on the back is visible.
Carefully peel the sticker using a screwdriver from an edge. This will reveal two Phillips screws.
Begin to open from the cable side. Carefully lift the side up like you would a hinge. The clips should un-clip themselves.
Remove all four screws on the edges of the PSU.
Carefully peel the shielding tape to release the PSU from it's place
Pull the shield towards the cable side and it should pop open. (Some force is required).
Disconnect the PSU connector.
PSU is free.
