This teardown is in progress – Reload periodically to see the latest changes!
  1. Alesis Palmtrack V3.1 Teardown, Alesis Palmtrack V3.1 Teardown: step 1, image 1 of 1
    • Open the back battery cover
  2. Alesis Palmtrack V3.1 Teardown: step 2, image 1 of 1
    • Unscrew the four back screws
  3. Alesis Palmtrack V3.1 Teardown: step 3, image 1 of 2 Alesis Palmtrack V3.1 Teardown: step 3, image 2 of 2
    • Remove the backing and the wire mesh microphone casing.
    • NOTE: The Speaker is connected to the motherboard and adhered to the back cover, so take caution when opening. I cannot foretell the chaos created if you break the speaker wire.
  4. Alesis Palmtrack V3.1 Teardown: step 4, image 1 of 1
    • Gently pull apart main plate from front cover.
    • Also note that there is a ribbon cable connecting the front circuit board to the motherboard
  5. Alesis Palmtrack V3.1 Teardown: step 5, image 1 of 1
    • Disconnect the ribbon cable.
  6. Alesis Palmtrack V3.1 Teardown: step 6, image 1 of 1
    • Feed the ribbon cable through this opening. This is much easier than disconnecting from the front circuit board, which requires delicate, if not impossible maneuvers to reconnect upon reassembly.
Lorca Strand
11 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 282
