This teardown is not a repair guide. To repair your Acer Liquid E1, use our service manual.
Remove the plastic back and the exposed battery.
Do not forget to remove sim- and SD-cards
Use a torx t5 to unscrew all screws. This will be the first and last time you'll use a screwdriver with this device.
Use a plastic opening tool or spudger
Pry around the side to release the backframe from the middleframe
Be careful as the frame is quite fragile
Tilting the main board will reveal this connection
Use a plastic spudger to open the lock
Carefully pull the flex cable out of it
Don't put alot of stress on it
At the bottom, use a pair of tweezers to remove the yellow tape from the connector
Use a plastic spudger to unlock
Pull the flexcable out carefully
Use a spudger to remove the bottom-plate from the frame.
Be careful when using metal tools (like I did)
Make sure the antenna cable isn't attached to anything except it's socket
Let the remaining heat at 95°C for about 3-5 minutes to soften the adhesive
Use an opening tool to pry at the top, between your digitizer and the middleframe
Open it from the top, your digitizer-flex runs at the bottom
Be careful when using a heat-gun. Heat-guns don't distribute heat evenly and LCD-burns may occur
To remove the LCD, remove the sticker on the back of the midframe. It conseals the LCD-flex
Be careful when removing the sticker. It's glued tightly and too much stress will tear the LCD-flex
Remove the LCD by pulling the whole cable through the midframe.
Embed this guide
Choose a size and copy the code below to embed this guide as a small widget on your site / forum.
Preview
