why! W670SZQ1 Processor Replacement
  1. why! W670SZQ1 Processor Replacement, The Batteries: step 1, image 1 of 3 why! W670SZQ1 Processor Replacement, The Batteries: step 1, image 2 of 3 why! W670SZQ1 Processor Replacement, The Batteries: step 1, image 3 of 3
    • Unlock the lock latch on the left.
    • Unlock the lock latch on the right.
    • Remove the battery while holding the lock latch unlocked.
  2. why! W670SZQ1 Processor Replacement, Access to Major Components: step 2, image 1 of 3 why! W670SZQ1 Processor Replacement, Access to Major Components: step 2, image 2 of 3 why! W670SZQ1 Processor Replacement, Access to Major Components: step 2, image 3 of 3
    • Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
    • Lift the bottom right cover with the iFixit Opening Tool.
    • Lift the lower left cover with the iFixit Opening Tool.
    • Finally clear the bottom cover completely to access the main components.
  3. why! W670SZQ1 Processor Replacement, The processor: step 3, image 1 of 3 why! W670SZQ1 Processor Replacement, The processor: step 3, image 2 of 3 why! W670SZQ1 Processor Replacement, The processor: step 3, image 3 of 3
    • Using the Phillips screwdriver, unscrew the 4 screws holding the processor cooling radiator.
    • Remove the cooling radiator. Once the radiator removed you can see the processor with its locking latch.
    • Now unlock the processor with a small screwdriver. Then remove it gently.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
Israel is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 138
