why! W670SZQ1 Fan Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. why! W670SZQ1 Fan Replacement, accumulator: step 1, image 1 of 3 why! W670SZQ1 Fan Replacement, accumulator: step 1, image 2 of 3 why! W670SZQ1 Fan Replacement, accumulator: step 1, image 3 of 3
    • Open the latch of the accumulator on the left side.
    • Open the battery latch on the right side.
    • Remove the accumulator by simultaneously holding the right-hand latch open.
  2. why! W670SZQ1 Fan Replacement, Access to the most important components: step 2, image 1 of 3 why! W670SZQ1 Fan Replacement, Access to the most important components: step 2, image 2 of 3 why! W670SZQ1 Fan Replacement, Access to the most important components: step 2, image 3 of 3
    • Use the Philips screwdriver to remove the two screws at the bottom of the cover.
    • Lift the cover at the bottom right with the iFixit Opening Tool
    • Lift the cover at the bottom left with the iFixit Opening Tool
    • Finally, remove the cover to gain access to the most important components.
  3. why! W670SZQ1 Fan Replacement, Fan: step 3, image 1 of 3 why! W670SZQ1 Fan Replacement, Fan: step 3, image 2 of 3 why! W670SZQ1 Fan Replacement, Fan: step 3, image 3 of 3
    • First, locate the fan. Then pull out the supply cable of the fan.
    • Remove the three retaining screws of the fan.
    • Finally, remove the fan by lifting it out.
Repeat the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 12
All Time: 114
