why! W670SZQ1 Processor replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. why! W670SZQ1 Processor replacement, accumulator: step 1, image 1 of 3 why! W670SZQ1 Processor replacement, accumulator: step 1, image 2 of 3 why! W670SZQ1 Processor replacement, accumulator: step 1, image 3 of 3
    • Open the latch of the accumulator on the left side.
    • Open the battery latch on the right side.
    • Remove the accumulator by simultaneously holding the right-hand latch open.
  2. why! W670SZQ1 Processor replacement, Access to the most important components: step 2, image 1 of 3 why! W670SZQ1 Processor replacement, Access to the most important components: step 2, image 2 of 3 why! W670SZQ1 Processor replacement, Access to the most important components: step 2, image 3 of 3
    • Use the Philips screwdriver to remove the two screws at the bottom of the cover.
    • Lift the cover at the bottom right with the iFixit Opening Tool
    • Lift the cover at the bottom left with the iFixit Opening Tool
    • Finally, remove the cover to gain access to the most important components.
  3. why! W670SZQ1 Processor replacement, Processor: step 3, image 1 of 3 why! W670SZQ1 Processor replacement, Processor: step 3, image 2 of 3 why! W670SZQ1 Processor replacement, Processor: step 3, image 3 of 3
    • With a Philips screwdriver, remove the 4 mounting screws of the heat sink.
    • Now remove the heat sink. Once the heat sink is removed you can see the processor with its lock.
    • Unlock the processor and remove it from its socket.
Repeat the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 70
