why! Replace the W670SZQ1 keyboard
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. why! Replace the W670SZQ1 keyboard, accumulator: step 1, image 1 of 3 why! Replace the W670SZQ1 keyboard, accumulator: step 1, image 2 of 3 why! Replace the W670SZQ1 keyboard, accumulator: step 1, image 3 of 3
    • Open the latch of the accumulator on the left side.
    • Open the battery latch on the right side.
    • Remove the accumulator by simultaneously holding the right-hand latch open.
  2. why! Replace the W670SZQ1 keyboard, Access to the most important components: step 2, image 1 of 3 why! Replace the W670SZQ1 keyboard, Access to the most important components: step 2, image 2 of 3 why! Replace the W670SZQ1 keyboard, Access to the most important components: step 2, image 3 of 3
    • Use the Philips screwdriver to remove the two screws at the bottom of the cover.
    • Lift the cover at the bottom right with the iFixit Opening Tool
    • Lift the cover at the bottom left with the iFixit Opening Tool
    • Finally, remove the cover to gain access to the most important components.
  3. why! Replace the W670SZQ1 keyboard, keyboard: step 3, image 1 of 3 why! Replace the W670SZQ1 keyboard, keyboard: step 3, image 2 of 3 why! Replace the W670SZQ1 keyboard, keyboard: step 3, image 3 of 3
    • Once the bottom cover is removed you can start disassembling the keyboard.
    • First, invert the calculator and then loosen the screw as shown in picture 2 of this step.
    • Then unzip the keyboard screw cover strip.
  4. why! Replace the W670SZQ1 keyboard: step 4, image 1 of 3 why! Replace the W670SZQ1 keyboard: step 4, image 2 of 3 why! Replace the W670SZQ1 keyboard: step 4, image 3 of 3
    • After the cover strip is removed, you can see the tip of the screwdriver.
    • Now locate the five fastening screws of the keyboard.
    • Loosen these five screws.
  5. why! Replace the W670SZQ1 keyboard: step 5, image 1 of 3 why! Replace the W670SZQ1 keyboard: step 5, image 2 of 3 why! Replace the W670SZQ1 keyboard: step 5, image 3 of 3
    • Lift the keyboard slightly and pull it slightly backwards.
    • The connection cables are now visible.
    • Now release the right lock on the plug of the keyboard light cable.
  6. why! Replace the W670SZQ1 keyboard: step 6, image 1 of 3 why! Replace the W670SZQ1 keyboard: step 6, image 2 of 3 why! Replace the W670SZQ1 keyboard: step 6, image 3 of 3
    • Then the left lock.
    • Now apply the same procedure to the plug of the main cable (left lock)
    • Right lock.
  7. why! Replace the W670SZQ1 keyboard: step 7, image 1 of 1
    • You can now remove the keyboard from its slot.
Repeat the steps in order to reassemble your device.
Special thanks to these translators:
de en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 93
