why! Replace the W670SZQ1 SSD hard drive
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. why! Replace the W670SZQ1 SSD hard drive, accumulator: step 1, image 1 of 3 why! Replace the W670SZQ1 SSD hard drive, accumulator: step 1, image 2 of 3 why! Replace the W670SZQ1 SSD hard drive, accumulator: step 1, image 3 of 3
    • Open the latch of the accumulator on the left side.
    • Open the battery latch on the right side.
    • Remove the accumulator by simultaneously holding the right-hand latch open.
  2. why! Replace the W670SZQ1 SSD hard drive, Access to the most important components: step 2, image 1 of 3 why! Replace the W670SZQ1 SSD hard drive, Access to the most important components: step 2, image 2 of 3 why! Replace the W670SZQ1 SSD hard drive, Access to the most important components: step 2, image 3 of 3
    • Use the Philips screwdriver to remove the two screws at the bottom of the cover.
    • Lift the cover at the bottom right with the iFixit Opening Tool
    • Lift the cover at the bottom left with the iFixit Opening Tool
    • Finally, remove the cover to gain access to the most important components.
  3. why! Replace the W670SZQ1 SSD hard drive, SSD hard drive: step 3, image 1 of 3 why! Replace the W670SZQ1 SSD hard drive, SSD hard drive: step 3, image 2 of 3 why! Replace the W670SZQ1 SSD hard drive, SSD hard drive: step 3, image 3 of 3
    • Remove the retaining screw of the SSD hard drive with the Philips screwdriver.
    • Remove the SSD hard drive.
Repeat the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 11
All Time: 95
