Parts
No parts required.
Start by unlocking the right locking latch. Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  • Start by unlocking the right locking latch.
  • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
Begin by spotting the dummy memory card. Then, remove it and put it on your workplan.
  • Begin by spotting the dummy memory card.
  • Then, remove it and put it on your workplan.
Locate the 15 screws that hold the bottom cover of the device in place. Unscrew them and place them on your work surface. Then, un-clip the bottom cover, starting with the side shown in the third picture.
  • Locate the 15 screws that hold the bottom cover of the device in place.
  • Unscrew them and place them on your work surface.
  • Then, un-clip the bottom cover, starting with the side shown in the third picture.
Locate the M.2 SSD in its slot. Unscrew the fastening screw of the latter. Lift and remove the SSD M.2 drive from its connector.
  • Locate the M.2 SSD in its slot.
  • Unscrew the fastening screw of the latter.
  • Lift and remove the SSD M.2 drive from its connector.
Locate the hard drive in its location. Lift it slightly. Finally remove it from its SATA connector.
  • Locate the hard drive in its location.
  • Lift it slightly.
  • Finally remove it from its SATA connector.
To reassemble your device, follow the instructions in reverse order. Lift it gently and take it out of its place.
  • To reassemble your device, follow the instructions in reverse order.
  • Lift it gently and take it out of its place.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Carefully unplug the MAIN and AUX antennas. Unscrew the fixing screw with the Philips # 0 screwdriver. Then lift the chipset slightly and remove it from the connector.
  • Carefully unplug the MAIN and AUX antennas.
  • Unscrew the fixing screw with the Philips # 0 screwdriver. Then lift the chipset slightly and remove it from the connector.
Find and separate the spring blades that maintain the memory module in place (right). Find and separate the spring blades that maintain the memory module in place (left). Remove the memory module (RAM) from its connector.
  • Find and separate the spring blades that maintain the memory module in place (right).
  • Find and separate the spring blades that maintain the memory module in place (left).
  • Remove the memory module (RAM) from its connector.
Remove the power cable from the fan. Unscrew the two screws securing the fan. Finally remove the fan and place it on your worktop.
  • Remove the power cable from the fan.
  • Unscrew the two screws securing the fan.
  • Finally remove the fan and place it on your worktop.
Unscrew the circled screws in green and red Put the computer in the position of the second image while pushing a paper clip into the hole of the screw circled in green until you hear a click Lift the keyboard
  • Unscrew the circled screws in green and red
  • Put the computer in the position of the second image while pushing a paper clip into the hole of the screw circled in green until you hear a click
  • Lift the keyboard
Disconnect the connector circled in red in the direction of the arrow Disconnect the connector circled in red in the direction of the arrow Disconnect the connector circled in red in the direction of the arrow
  • Disconnect the connector circled in red in the direction of the arrow
Locate the two flat cables and remove them carefully. Locate the two flat cables and remove them carefully. Locate the two flat cables and remove them carefully.
  • Locate the two flat cables and remove them carefully.
Locate the five connectors on the motherboard Unplug all connectors Unplug all connectors
  • Locate the five connectors on the motherboard
  • Unplug all connectors
Unplug all connectors Unplug all connectors Unplug all connectors
Unscrew the four screws circled in red Lift the motherboard by taking it through the radiator
  • Unscrew the four screws circled in red
  • Lift the motherboard by taking it through the radiator
Disconnect the two connectors circled in red Disconnect the two connectors circled in red Disconnect the two connectors circled in red
  • Disconnect the two connectors circled in red
Special thanks to these translators:
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
14,251 Reputation
338 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 71
