why! W670SZQ1 Processor replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. why! W670SZQ1 Processor replacement, accumulator: step 1, image 1 of 3 why! W670SZQ1 Processor replacement, accumulator: step 1, image 2 of 3 why! W670SZQ1 Processor replacement, accumulator: step 1, image 3 of 3
      • Open the latch of the accumulator on the left side.
      • Open the battery latch on the right side.
      • Remove the accumulator by simultaneously holding the right-hand latch open.
      Ask FixBot
    1. why! W670SZQ1 Processor replacement, Access to the most important components: step 2, image 1 of 3 why! W670SZQ1 Processor replacement, Access to the most important components: step 2, image 2 of 3 why! W670SZQ1 Processor replacement, Access to the most important components: step 2, image 3 of 3
      • Use the Philips screwdriver to remove the two screws at the bottom of the cover.
      • Lift the cover at the bottom right with the iFixit Opening Tool
      • Lift the cover at the bottom left with the iFixit Opening Tool
      • Finally, remove the cover to gain access to the most important components.
      Ask FixBot
    1. why! W670SZQ1 Processor replacement, Processor: step 3, image 1 of 3 why! W670SZQ1 Processor replacement, Processor: step 3, image 2 of 3 why! W670SZQ1 Processor replacement, Processor: step 3, image 3 of 3
      • With a Philips screwdriver, remove the 4 mounting screws of the heat sink.
      • Now remove the heat sink. Once the heat sink is removed you can see the processor with its lock.
      • Unlock the processor and remove it from its socket.
      Ask FixBot
Repeat the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 19
All Time: 315
