This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
why! W650SZ LCD Screen Replacement
    1. why! W650SZ LCD Screen Replacement, Battery: step 1, image 1 of 3 why! W650SZ LCD Screen Replacement, Battery: step 1, image 2 of 3 why! W650SZ LCD Screen Replacement, Battery: step 1, image 3 of 3
      • Slide the latch on the right to the unlocked position.
      • Slide the latch on the left to the unlocked position.
      • Remove the battery pack from the slot.
      Ask FixBot
    1. why! W650SZ LCD Screen Replacement, Remove the Bezel: step 2, image 1 of 3 why! W650SZ LCD Screen Replacement, Remove the Bezel: step 2, image 2 of 3 why! W650SZ LCD Screen Replacement, Remove the Bezel: step 2, image 3 of 3
      • Although the photos are shown without a keyboard, it is not necessary to remove the keyboard to replace the screen.
      • Gently insert your fingernail between the display bezel and the LCD.
      Ask FixBot
    2. why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): step 3, image 1 of 3 why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): step 3, image 2 of 3 why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): step 3, image 3 of 3
      • Working your way around the frame, unclip the mounting points of the frame surrounding the LCD screen.
      Ask FixBot
    3. why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): step 4, image 1 of 3 why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): step 4, image 2 of 3 why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): step 4, image 3 of 3
      • Remove the bezel surrounding the LCD.
      Ask FixBot
    4. why! W650SZ LCD Screen Replacement, Remove the Screws Securing the LCD: step 5, image 1 of 3 why! W650SZ LCD Screen Replacement, Remove the Screws Securing the LCD: step 5, image 2 of 3 why! W650SZ LCD Screen Replacement, Remove the Screws Securing the LCD: step 5, image 3 of 3
      • Remove the two upper mounting screws securing the LCD to the lid.
      • Remove the two lower mounting screws.
      Ask FixBot
    5. why! W650SZ LCD Screen Replacement, Separate the LCD from the Display: step 6, image 1 of 3 why! W650SZ LCD Screen Replacement, Separate the LCD from the Display: step 6, image 2 of 3 why! W650SZ LCD Screen Replacement, Separate the LCD from the Display: step 6, image 3 of 3
      • Cover the keyboard with a cloth, then carefully lower the LCD screen onto the keyboard.
      Ask FixBot
    6. why! W650SZ LCD Screen Replacement, Disconnect the LCD Cable: step 7, image 1 of 3 why! W650SZ LCD Screen Replacement, Disconnect the LCD Cable: step 7, image 2 of 3 why! W650SZ LCD Screen Replacement, Disconnect the LCD Cable: step 7, image 3 of 3
      • Note the location of the LCD screen connector.
      Ask FixBot
    7. why! W650SZ LCD Screen Replacement, Remove the Connector Tape: step 8, image 1 of 3 why! W650SZ LCD Screen Replacement, Remove the Connector Tape: step 8, image 2 of 3 why! W650SZ LCD Screen Replacement, Remove the Connector Tape: step 8, image 3 of 3
      • Using the plastic tab, peel back the tape securing the LCD cable the panel connector.
      Ask FixBot
    8. why! W650SZ LCD Screen Replacement, Unplug the LCD and Remove the Screen: step 9, image 1 of 3 why! W650SZ LCD Screen Replacement, Unplug the LCD and Remove the Screen: step 9, image 2 of 3 why! W650SZ LCD Screen Replacement, Unplug the LCD and Remove the Screen: step 9, image 3 of 3
      • Unplug the connector.
      • The LCD screen can now be removed.
      Ask FixBot
Special thanks to these translators:
fr en
100%
Jerry Wheeler is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 59
All Time: 511
