why! N240JU Replacing the LCD screen
  1. why! N240JU Replacing the LCD screen, Battery: step 1, image 1 of 2 why! N240JU Replacing the LCD screen, Battery: step 1, image 2 of 2
    • Start by unlocking the right locking latch.
    • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  2. why! N240JU Replacing the LCD screen, Access to main components: step 2, image 1 of 2 why! N240JU Replacing the LCD screen, Access to main components: step 2, image 2 of 2
    • Begin by spotting the dummy memory card.
    • Then, remove it and put it on your workplan.
  3. why! N240JU Replacing the LCD screen: step 3, image 1 of 3 why! N240JU Replacing the LCD screen: step 3, image 2 of 3 why! N240JU Replacing the LCD screen: step 3, image 3 of 3
    • Locate the 15 screws that hold the bottom cover of the device in place.
    • Unscrew them and place them on your work surface.
    • Then, un-clip the bottom cover, starting with the side shown in the third picture.
  4. why! N240JU Replacing the LCD screen, LCD screen: step 4, image 1 of 3 why! N240JU Replacing the LCD screen, LCD screen: step 4, image 2 of 3 why! N240JU Replacing the LCD screen, LCD screen: step 4, image 3 of 3
    • In order to remove the LCD screen, you must remove the connection cables from the Wi-Fi chipset.
    • Then locate the two connectors on the LCD screen.
    • Disconnect the first connector.
  5. why! N240JU Replacing the LCD screen: step 5, image 1 of 3 why! N240JU Replacing the LCD screen: step 5, image 2 of 3 why! N240JU Replacing the LCD screen: step 5, image 3 of 3
    • Peel off the tape from the second connector.
    • Then disconnect the second connector.
    • Locate the SSD M.2 drive.
  6. why! N240JU Replacing the LCD screen: step 6, image 1 of 3 why! N240JU Replacing the LCD screen: step 6, image 2 of 3 why! N240JU Replacing the LCD screen: step 6, image 3 of 3
    • Then dismount this disk because it must release the connection cables of the Wi-Fi chipset.
    • Free Wi-Fi connection cables now
    • Now locate the two screws that secure the screen to the rest of the Laptop (fan side)
  7. why! N240JU Replacing the LCD screen: step 7, image 1 of 3 why! N240JU Replacing the LCD screen: step 7, image 2 of 3 why! N240JU Replacing the LCD screen: step 7, image 3 of 3
    • Now locate the two screws that secure the screen to the rest of the Laptop (the other side).
    • Then lift the Laptop as shown in the second image of this step.
    • Unscrew the first screw.
  8. why! N240JU Replacing the LCD screen: step 8, image 1 of 3 why! N240JU Replacing the LCD screen: step 8, image 2 of 3 why! N240JU Replacing the LCD screen: step 8, image 3 of 3
    • Then unscrew the second screw.
    • Rest the Laptop as shown in the second image of this step and unscrew the third screw.
    • Then the fourth screw.
  9. why! N240JU Replacing the LCD screen: step 9, image 1 of 3 why! N240JU Replacing the LCD screen: step 9, image 2 of 3 why! N240JU Replacing the LCD screen: step 9, image 3 of 3
    • With the four screws unscrewed, separate the screen from the rest of the Laptop. Note that the hinge remains attached to the screen.
    • On the screen near the hinge now locate the two caches screws on the left.
    • Then look for those on the right.
  10. why! N240JU Replacing the LCD screen: step 10, image 1 of 3 why! N240JU Replacing the LCD screen: step 10, image 2 of 3 why! N240JU Replacing the LCD screen: step 10, image 3 of 3
    • Now remove the screw covers near the left hinge.
    • first on the right side of the hinge.
    • then on the left side.
  11. why! N240JU Replacing the LCD screen: step 11, image 1 of 3 why! N240JU Replacing the LCD screen: step 11, image 2 of 3 why! N240JU Replacing the LCD screen: step 11, image 3 of 3
    • Repeat near the right hinge
    • .Now return to the hinge on the left side and unscrew the outer screw.
  12. why! N240JU Replacing the LCD screen: step 12, image 1 of 3 why! N240JU Replacing the LCD screen: step 12, image 2 of 3 why! N240JU Replacing the LCD screen: step 12, image 3 of 3
    • Then unscrew the inner screw.
    • Repeat on the side of the right hinge.
  13. why! N240JU Replacing the LCD screen: step 13, image 1 of 3 why! N240JU Replacing the LCD screen: step 13, image 2 of 3 why! N240JU Replacing the LCD screen: step 13, image 3 of 3
    • You can now gently unclip the screen cover.
    • Locate the left hinge screw cover.
    • Locate the right hinge screw cover.
  14. why! N240JU Replacing the LCD screen: step 14, image 1 of 3 why! N240JU Replacing the LCD screen: step 14, image 2 of 3 why! N240JU Replacing the LCD screen: step 14, image 3 of 3
    • Gently remove the screw cover on the left hinge.
    • Also remove the screw cover on the right hinge.
    • Once the screw caps are removed you will see the fixing screws.
  15. why! N240JU Replacing the LCD screen: step 15, image 1 of 3 why! N240JU Replacing the LCD screen: step 15, image 2 of 3 why! N240JU Replacing the LCD screen: step 15, image 3 of 3
    • Now unscrew the screw on the left hinge.
    • Then unscrew the screw on the right hinge.
    • Once this is done you can now remove the hinge cover (left).
  16. why! N240JU Replacing the LCD screen: step 16, image 1 of 3 why! N240JU Replacing the LCD screen: step 16, image 2 of 3 why! N240JU Replacing the LCD screen: step 16, image 3 of 3
    • Left hinged cover removed.
    • Then remove the cover from the right hinge.
    • Right hinge cover removed.
  17. why! N240JU Replacing the LCD screen: step 17, image 1 of 3 why! N240JU Replacing the LCD screen: step 17, image 2 of 3 why! N240JU Replacing the LCD screen: step 17, image 3 of 3
    • once these operations are done you see the LCD screen ready to be dismounted.
    • Now locate the screws that secure the LCD screen to the bracket and unscrew them. Two on the left.
    • Two on the right.
  18. why! N240JU Replacing the LCD screen: step 18, image 1 of 3 why! N240JU Replacing the LCD screen: step 18, image 2 of 3 why! N240JU Replacing the LCD screen: step 18, image 3 of 3
    • Once the screws are unscrewed, lift the LCD screen gently and flip it over.
    • You will then see the connection cable of the screen.
    • Locate its connector.
  19. why! N240JU Replacing the LCD screen: step 19, image 1 of 2 why! N240JU Replacing the LCD screen: step 19, image 2 of 2
    • Disconnect the cable.
    • And here you can now put it on your work plan.
To reassemble your device, Follow these instructions in reverse order.
Special thanks to these translators:
fr en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,538 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 550
