why! N240JU Replacing SSD M.2 Disk
  1. why! N240JU Replacing SSD M.2 Disk, Battery: step 1, image 1 of 2 why! N240JU Replacing SSD M.2 Disk, Battery: step 1, image 2 of 2
    • Start by unlocking the right locking latch.
    • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  2. why! N240JU Replacing SSD M.2 Disk, Access to main components: step 2, image 1 of 2 why! N240JU Replacing SSD M.2 Disk, Access to main components: step 2, image 2 of 2
    • Begin by spotting the dummy memory card.
    • Then, remove it and put it on your workplan.
  3. why! N240JU Replacing SSD M.2 Disk: step 3, image 1 of 3 why! N240JU Replacing SSD M.2 Disk: step 3, image 2 of 3 why! N240JU Replacing SSD M.2 Disk: step 3, image 3 of 3
    • Locate the 15 screws that hold the bottom cover of the device in place.
    • Unscrew them and place them on your work surface.
    • Then, un-clip the bottom cover, starting with the side shown in the third picture.
  4. why! N240JU Replacing SSD M.2 Disk, SSD M.2 disk: step 4, image 1 of 3 why! N240JU Replacing SSD M.2 Disk, SSD M.2 disk: step 4, image 2 of 3 why! N240JU Replacing SSD M.2 Disk, SSD M.2 disk: step 4, image 3 of 3
    • Locate the M.2 SSD in its slot.
    • Unscrew the fastening screw of the latter.
    • Lift and remove the SSD M.2 drive from its connector.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
Israel is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 13
All Time: 375
