This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Introduction
This guide shows you how to replace the lower screen frame of a why! L140/1PU by unscrewing the two screws that hold it in place, before releasing it from the screen.
The zones we will focus on are indicated.
Unplug the screen cable.
Unscrew the screw of the cover and those of the hinge. Remove the cover.
Unscrew the screw of the cover, as well as those of the clutch hinge. Remove the cover.
Unplug the Wifi cables.
Remove the upper case, separating it from the screen.
Using a hair dryer, blow hot air around the screen to soften the frame's adhesive.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
