This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Introduction
This guide shows you how to replace the camera in a why! L140/1PU laptop.
The zones we will focus on are indicated.
Unplug the screen cable.
Unscrew the screw of the cover and those of the hinge. Remove the cover.
Unscrew the screw of the cover, as well as those of the clutch hinge. Remove the cover.
Unplug the Wifi cables.
Remove the upper case, separating it from the screen.
Using a hair dryer, blow hot air around the screen to soften the frame's adhesive.
Pull the tape until it is freed. Repeat on all 3 other sides.
Lift up the screen.
Peel the camera up.
Disconnect the cable by lifting the small black flap.
Follow these instructions in reverse order to reassemble your device.
