Video Overview
Featured Document
This teardown is not a repair guide. To repair your WebScreen, use our service manual.
  1. WebScreen Teardown, Remove the Side Screw from the Enclosure: step 1, image 1 of 3 WebScreen Teardown, Remove the Side Screw from the Enclosure: step 1, image 2 of 3 WebScreen Teardown, Remove the Side Screw from the Enclosure: step 1, image 3 of 3
    • Description: The side screw secures the enclosure and must be removed first.
    • Action: Use a precision screwdriver to remove the M1.5 side screw.
    Ask FixBot
  2. WebScreen Teardown, Remove the Bottom Cover of the Enclosure: step 2, image 1 of 3 WebScreen Teardown, Remove the Bottom Cover of the Enclosure: step 2, image 2 of 3 WebScreen Teardown, Remove the Bottom Cover of the Enclosure: step 2, image 3 of 3
    • Description: Removing the bottom cover provides access to the interior of the WebScreen.
    • Action: ○​ Carefully slide off the bottom cover. ○​ Pay special attention to the power button, ensuring it is not lost if it becomes detached.
    Ask FixBot
  3. WebScreen Teardown, Lift the Electronic Board (PCB): step 3, image 1 of 2 WebScreen Teardown, Lift the Electronic Board (PCB): step 3, image 2 of 2
    • Description: The main PCB must be lifted carefully to avoid damaging the flexible connectors.
    • Action: Hold the edges of the PCB and gently lift it.
    Ask FixBot
  4. WebScreen Teardown, Remove the M1.5 Screw to Release the Upper Enclosure: step 4, image 1 of 2 WebScreen Teardown, Remove the M1.5 Screw to Release the Upper Enclosure: step 4, image 2 of 2
    • Description: An M1.5 screw secures the upper enclosure and must be removed to release the display.
    • Action: ○​ Locate and remove the M1.5 screw. ○​ Ensure that the display is completely free.
    Ask FixBot
  5. WebScreen Teardown, Remove the Upper Enclosure: step 5, image 1 of 3 WebScreen Teardown, Remove the Upper Enclosure: step 5, image 2 of 3 WebScreen Teardown, Remove the Upper Enclosure: step 5, image 3 of 3
    • Description: With both elements removed, the PCB connected to the display is now accessible.​
    • Action: ●​ Separate the enclosure pieces. ●​ Check the orientation of the PCB and display connectors.
    Ask FixBot
  6. WebScreen Teardown, Remove the PCB along with the Connected Display: step 6, image 1 of 3 WebScreen Teardown, Remove the PCB along with the Connected Display: step 6, image 2 of 3 WebScreen Teardown, Remove the PCB along with the Connected Display: step 6, image 3 of 3
    • Description: With the enclosure disassembled, the PCB along with the display can be removed as a single unit.
    • Action: ●​ Carefully hold the PCB and display, ensuring there are no forced connections. ●​ Slowly lift both components at the same time.
    Ask FixBot
  7. WebScreen Teardown, Disconnect the Display: step 7, image 1 of 3 WebScreen Teardown, Disconnect the Display: step 7, image 2 of 3 WebScreen Teardown, Disconnect the Display: step 7, image 3 of 3
    • Description: With the PCB removed from the enclosure, the display can now be disconnected.​
    • Action: ●​ Use anti-static tweezers to gently disconnect the display’s flex cable. ●​ Ensure there are no active connections before fully removing it.
    Ask FixBot
Attached Documents
HW Lab
160 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 26
All Time: 564
