uAttend bn6000 Keyboard Replacement
  1. uAttend bn6000 Keyboard Replacement, Disassembly: step 1, image 1 of 1
    • Make sure to unplug the device before starting.
    • Flip the device over.
    • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
  2. uAttend bn6000 Keyboard Replacement: step 2, image 1 of 1
    • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
  3. uAttend bn6000 Keyboard Replacement, Keyboard: step 3, image 1 of 2 uAttend bn6000 Keyboard Replacement, Keyboard: step 3, image 2 of 2
    • Remove the five 7mm PH #1 screws from the back of the keypad, by rotating the screw driver counter clockwise, removing the screw from the housing completely.
  4. uAttend bn6000 Keyboard Replacement: step 4, image 1 of 1
    • Remove the bundled cable connector from the keyboard by pulling the cable away from the connector in the same direction as the individual wires are running.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 5
All Time: 228
