sonyo pro extraX multiverse projector bulb replacement Replacement
  1. sonyo pro extraX multiverse projector bulb replacement Replacement, bulb replacement: step 1, image 1 of 1
    • Remove one 9mm screw with a Phillips 2 screwdriver.
  2. sonyo pro extraX multiverse projector bulb replacement Replacement: step 2, image 1 of 2 sonyo pro extraX multiverse projector bulb replacement Replacement: step 2, image 2 of 2
    • Use a spudger to lift up the panel, then set it off to the side.
  3. sonyo pro extraX multiverse projector bulb replacement Replacement: step 3, image 1 of 2 sonyo pro extraX multiverse projector bulb replacement Replacement: step 3, image 2 of 2
    • Remove three 11mm screws with a Phillips 2 screwdriver.
  4. sonyo pro extraX multiverse projector bulb replacement Replacement: step 4, image 1 of 3 sonyo pro extraX multiverse projector bulb replacement Replacement: step 4, image 2 of 3 sonyo pro extraX multiverse projector bulb replacement Replacement: step 4, image 3 of 3
    • Pinch on the two plastic clips and lift up to remove the bulb completely.
Matt Block
286 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 422
