Screen Assembly Removal
  1. Screen Assembly Removal, Turn off the watch: step 1, image 1 of 2 Screen Assembly Removal, Turn off the watch: step 1, image 2 of 2
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
    Ask FixBot
  2. Screen Assembly Removal, Remove the rear screws: step 2, image 1 of 1
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
    Ask FixBot
  3. Screen Assembly Removal, Separate the back cover from the housing: step 3, image 1 of 3 Screen Assembly Removal, Separate the back cover from the housing: step 3, image 2 of 3 Screen Assembly Removal, Separate the back cover from the housing: step 3, image 3 of 3
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
    Ask FixBot
  4. Screen Assembly Removal, Disconnect the sensor array: step 4, image 1 of 2 Screen Assembly Removal, Disconnect the sensor array: step 4, image 2 of 2
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
    Ask FixBot
  5. Screen Assembly Removal, Remove the back cover: step 5, image 1 of 1
    • Remove the back cover.
    Ask FixBot
  6. Screen Assembly Removal, Disconnect the display and the mic array: step 6, image 1 of 3 Screen Assembly Removal, Disconnect the display and the mic array: step 6, image 2 of 3 Screen Assembly Removal, Disconnect the display and the mic array: step 6, image 3 of 3
    • Use a spudger to disconnect the display assembly and the microphone and pressure sensor array.
    Ask FixBot
  7. Screen Assembly Removal, Undo the mic tape: step 7, image 1 of 3 Screen Assembly Removal, Undo the mic tape: step 7, image 2 of 3 Screen Assembly Removal, Undo the mic tape: step 7, image 3 of 3
    • Use an opening pick to peel back the thin tape belonging to the microphone array.
    • When re-assembling make sure this tape properly sticks to the motherboard by pressing it down with the flat end of a spudger.
    Ask FixBot
  8. Screen Assembly Removal, Lift the core assembly: step 8, image 1 of 2 Screen Assembly Removal, Lift the core assembly: step 8, image 2 of 2
    • Insert an opening pick at the bottom right between the motherboard and the frame to lift up the core assembly.
    Ask FixBot
  9. Screen Assembly Removal, Remove the core assembly: step 9, image 1 of 3 Screen Assembly Removal, Remove the core assembly: step 9, image 2 of 3 Screen Assembly Removal, Remove the core assembly: step 9, image 3 of 3
    • Lift out and remove the core assembly.
    Ask FixBot
  10. Screen Assembly Removal, Loosen the mic: step 10, image 1 of 2 Screen Assembly Removal, Loosen the mic: step 10, image 2 of 2
    • Use a spudger to loosen the microphone which is fixed to the frame with mild adhesive.
    Ask FixBot
  11. Screen Assembly Removal, Free the barometric sensor: step 11, image 1 of 2 Screen Assembly Removal, Free the barometric sensor: step 11, image 2 of 2
    • Use a spudger to lift the pressure sensor up and out of its recess in the frame.
    Ask FixBot
  12. Screen Assembly Removal, Remove the mic array: step 12, image 1 of 1
    • Carefully remove the microphone and barometric sensor array from the frame.
    Ask FixBot
Finish Line
Tobias Isakeit
134,306 Reputation
189 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 47
All Time: 940
