iomega LDHD250-U Teardown
  1. iomega LDHD250-U Teardown, Remove Rear Screws: step 1, image 1 of 1
    • Remember to power off and unplug the unit before opening it up!
    • Remove the two PH #0 Screws
  2. iomega LDHD250-U Teardown, Removing the cover: step 2, image 1 of 2 iomega LDHD250-U Teardown, Removing the cover: step 2, image 2 of 2
    • After removing the back part of the unit, slide the front part out.
    • Remember to put aside the center part you removed
  3. iomega LDHD250-U Teardown, Removing the Hard Drive: step 3, image 1 of 3 iomega LDHD250-U Teardown, Removing the Hard Drive: step 3, image 2 of 3 iomega LDHD250-U Teardown, Removing the Hard Drive: step 3, image 3 of 3
    • There are two ways to remove the Hard Drive
    • 1. Removing the 4 screws on the side of the unit
    • 2. Sliding the HDD back and then releasing it (my unit will not slide back)
    • The HDD can now be lifted out, unplugged, and replaced, upgraded, or keep it the same.
    • Pull up and unplug as the cables can break if too much force is applied
Nate Pritzker
431 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 25
All Time: 1,019
