iRobot Looj 120 Controller Buttons Replacement
    1. iRobot Looj 120 Controller Buttons Replacement, Removing Screws: step 1, image 1 of 1
      • Remove the four exterior screws located under controller and on the handle.
      • Remove the five screws shown, and then carefully remove top plate. Electrical components are attached to top plate.
      Ask FixBot
    2. iRobot Looj 120 Controller Buttons Replacement, Locate Circuitry: step 2, image 1 of 1
      • Disconnect circuit board from power leads, and install new circuit board.
      Ask FixBot
    1. iRobot Looj 120 Controller Buttons Replacement, Remove Exterior Screws: step 3, image 1 of 1
      • Remove the four exterior screws to gain access to inner components. These screws are located on the bottom of the controller and on the handle.
      • Remove the five interior screws to access the buttons.
      Ask FixBot
    2. iRobot Looj 120 Controller Buttons Replacement, Accessing the Buttons: step 4, image 1 of 1
      • Remove top plate carefully so that none of the electrical components are damaged.
      • Remove the broken button and insert the new button into the mounting hole.
      Ask FixBot
Lucas Otto
101 Reputation
1 Guide authored
UMass Dartmouth, Team 2-5, Duarte Fall 2014 Member of UMass Dartmouth, Team 2-5, Duarte Fall 2014
UMASSD-DUARTE-F14S2G5
3 Members
83 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 93
All Time: 627
