iRobot Roomba i7 Motorized Wheels Replacement
  1. iRobot Roomba i7 Motorized Wheels Replacement, Motorized Wheels: step 1, image 1 of 2 iRobot Roomba i7 Motorized Wheels Replacement, Motorized Wheels: step 1, image 2 of 2
    • Before you begin using this guide, make sure that your Roomba is turned off, and disconnected from the charging station, or Home Base.
    • Flip the iRobot Roomba i7 so that the underside is facing upwards.
    • Using the Philips #1 screwdriver, unscrew the 6.27mm-screw in the center of the side brush.
  2. iRobot Roomba i7 Motorized Wheels Replacement: step 2, image 1 of 3 iRobot Roomba i7 Motorized Wheels Replacement: step 2, image 2 of 3 iRobot Roomba i7 Motorized Wheels Replacement: step 2, image 3 of 3
    • After unscrewing the side brush screw, gently pull the brush up, as shown in the picture.
    • If the side brush is difficult to pull, use a plastic opening tool to take it out.
  3. iRobot Roomba i7 Motorized Wheels Replacement: step 3, image 1 of 2 iRobot Roomba i7 Motorized Wheels Replacement: step 3, image 2 of 2
    • Use the Phillips #1 screwdriver to unscrew the five 6.24mm screws retaining the underside cover.
    • Gently lift the underside cover off of your Roomba, exposing the inside components.
  4. iRobot Roomba i7 Motorized Wheels Replacement: step 4, image 1 of 2 iRobot Roomba i7 Motorized Wheels Replacement: step 4, image 2 of 2
    • Using a Phillips #1 screwdriver, unscrew the two 4.37mm-screws retaining the motorized wheels.
    • Lift the motorized wheel out of the Roomba to be replaced.
Past 24 Hours: 6
Past 7 Days: 17
Past 30 Days: 61
All Time: 6,722
