Introduction
Is your iRobot Roomba i7, not charging when connected to the Home Base? Is your device not turning on? In order to fix this problem, you must remove and replace the battery in your device. This guide will help you replace the battery on your iRobot Roomba i7.
The battery for the iRobot Roomba i7 is located in the the center of the device, directly in front of the iRobot Roomba i7 dual roller rubber brush system. The function of the battery is to store, and provide electricity to the entire device. The average run time of the iRobot Roomba i7 is 1 hour and 15 minutes.
Before you begin using this guide, make sure that your Roomba is turned off, and disconnected from the charging station, or Home Base.
Warning: Swollen or cracked batteries can be hazardous to humans due to fumes or potential fire. If you feel unsafe at anytime completing this guide, put your device in a fireproof container and take it to a replacement professional.
Flip the iRobot Roomba i7 so that the underside is facing upwards.
Using a Phillips #1 screwdriver, loosen the following screws:
6.27mm-screw in the center of the side brush.
Five 6.24mm-screws on the bottom cover.
Carefully remove the bottom cover.
If the cover is stuck or hard to remove, use a prying tool to separate it from the device.
Close the Roomba app on your mobile.
Remove the battery.
Hold the start button for 10 seconds.
Reinstall the battery and charge for a full cycle. Wait for your Roomba to automatically start itself.
Open the mobile app and reconnect to your Roomba.
