iRobot Roomba i7 Battery Replacement
  1. iRobot Roomba i7 Battery Replacement, Battery: step 1, image 1 of 3 iRobot Roomba i7 Battery Replacement, Battery: step 1, image 2 of 3 iRobot Roomba i7 Battery Replacement, Battery: step 1, image 3 of 3
    • Warning: Swollen or cracked batteries can be hazardous to humans due to fumes or potential fire. If you feel unsafe at anytime completing this guide, put your device in a fireproof container and take it to a replacement professional.
    • Flip the iRobot Roomba i7 so that the underside is facing upwards.
    • Using a Phillips #1 screwdriver, loosen the following screws:
    • 6.27mm-screw in the center of the side brush.
    • Five 6.24mm-screws on the bottom cover.
  2. iRobot Roomba i7 Battery Replacement: step 2, image 1 of 1
    • Carefully remove the bottom cover.
    • If the cover is stuck or hard to remove, use a prying tool to separate it from the device.
  3. iRobot Roomba i7 Battery Replacement: step 3, image 1 of 2 iRobot Roomba i7 Battery Replacement: step 3, image 2 of 2
    • Before removing the battery, make sure that it is not hot or swollen. Swollen lithium-ion batteries release gases that are hazardous for humans.
    • Unclip the original battery and pull upwards to remove it.
    • Use a prying tool if necessary.
Past 24 Hours: 14
Past 7 Days: 104
Past 30 Days: 496
All Time: 25,381
