iRobot Roomba 890 IR Sensor Replacement
  1. iRobot Roomba 890 IR Sensor Replacement, IR sensor: step 1, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the two 11 mm screws.
    • Remove the battery cover.
  2. iRobot Roomba 890 IR Sensor Replacement: step 2, image 1 of 2 iRobot Roomba 890 IR Sensor Replacement: step 2, image 2 of 2
    • Pull directly up on the grey pull-tabs to remove the battery.
  3. iRobot Roomba 890 IR Sensor Replacement: step 3, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the one 7.7 mm screw.
    • Remove the yellow brush head.
  4. iRobot Roomba 890 IR Sensor Replacement: step 4, image 1 of 3 iRobot Roomba 890 IR Sensor Replacement: step 4, image 2 of 3 iRobot Roomba 890 IR Sensor Replacement: step 4, image 3 of 3
    • Use a Phillips #2 screwdriver to unscrew the two 11 mm screws.
    • Lift the baseplate up and off.
  5. iRobot Roomba 890 IR Sensor Replacement: step 5, image 1 of 2 iRobot Roomba 890 IR Sensor Replacement: step 5, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the ten 9.3 mm screws.
    • Remove the bumper retainer ring.
  6. iRobot Roomba 890 IR Sensor Replacement: step 6, image 1 of 2 iRobot Roomba 890 IR Sensor Replacement: step 6, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the two 7.5 mm screws holding the IR sensor in place.
  7. iRobot Roomba 890 IR Sensor Replacement: step 7, image 1 of 2 iRobot Roomba 890 IR Sensor Replacement: step 7, image 2 of 2
    • Use an iFixit opening tool to remove the outer plastic covering from the top of the Roomba.
  8. iRobot Roomba 890 IR Sensor Replacement: step 8, image 1 of 3 iRobot Roomba 890 IR Sensor Replacement: step 8, image 2 of 3 iRobot Roomba 890 IR Sensor Replacement: step 8, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the two 9.5 mm handlebar screws; then remove the handle.
    • Use a Phillips #1 screwdriver to remove the fourteen 9.5 mm top plate screws.
    • Lift off the top plate.
  9. iRobot Roomba 890 IR Sensor Replacement: step 9, image 1 of 3 iRobot Roomba 890 IR Sensor Replacement: step 9, image 2 of 3 iRobot Roomba 890 IR Sensor Replacement: step 9, image 3 of 3
    Tool used on this step:
    $3.99
    Buy
    • Use a pair of angled tweezers to firmly grip the IR sensor plug, and pull it directly backwards to release it from the motherboard.
Caeden Foxhoven
331 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 37
All Time: 1,333
