iRobot Roomba 630 Side Brush Motor Replacement
  1. iRobot Roomba 630 Side Brush Motor Replacement, Side Brush Motor: step 1, image 1 of 2 iRobot Roomba 630 Side Brush Motor Replacement, Side Brush Motor: step 1, image 2 of 2
    • Flip the Roomba over so that the wheels are facing upwards.
    • Unscrew the 6 mm screw from the yellow side brush using a Phillips #2 screwdriver.
  2. iRobot Roomba 630 Side Brush Motor Replacement: step 2, image 1 of 2 iRobot Roomba 630 Side Brush Motor Replacement: step 2, image 2 of 2
    • Remove the four 10.1 mm screws from the back cover using a Phillips #2 screwdriver.
    • Lift the back cover off to access the gear box.
  3. iRobot Roomba 630 Side Brush Motor Replacement: step 3, image 1 of 3 iRobot Roomba 630 Side Brush Motor Replacement: step 3, image 2 of 3 iRobot Roomba 630 Side Brush Motor Replacement: step 3, image 3 of 3
    • Remove the three outer 15 mm screws that hold down the gearbox using a Phillips #2 screwdriver.
    • Remove the middle 15 mm screw to release the gearbox using a tri-point Y0 screwdriver.
    • Lift the blue side brush gear box out.
  4. iRobot Roomba 630 Side Brush Motor Replacement: step 4, image 1 of 2 iRobot Roomba 630 Side Brush Motor Replacement: step 4, image 2 of 2
    • Pry the top of the gear box off.
    • Check for debris in the gear box and clean it out if needed.
  5. iRobot Roomba 630 Side Brush Motor Replacement: step 5, image 1 of 3 iRobot Roomba 630 Side Brush Motor Replacement: step 5, image 2 of 3 iRobot Roomba 630 Side Brush Motor Replacement: step 5, image 3 of 3
    • Remove the screws holding the motor in place using a Phillips #2 screwdriver.
    • Pull the old motor out.
4 other people completed this guide.
Jabari Baptiste
485 Reputation
3 Guides authored
USF Tampa, Team S5-G3, Walkup Fall 2017 Member of USF Tampa, Team S5-G3, Walkup Fall 2017
USFT-WALKUP-F17S5G3
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 41
All Time: 1,994
