Introduction
This guide will teach the user how to take apart their device, disconnect an old logic board, and reattach a new one.
Using a Philips head #00 screwdriver locate and remove each of the four screws located along the tall side of the iRulu.
Use the opening tool to pry the screen from the case applying pressure at each of the four corners of the screen.
Using a pair of tweezers, gently unplug connectors A and B from the logic board.
Completely separate the screen and case.
Locate where the speaker wires are attached to the logic board, and use a soldering iron and solder sucker to remove the wires from the board.
Then, locate the wires connecting the logic board to the battery and desolder them the same way.
Completely remove the old logic board, being careful not to damage any wires
Place the new logic board exactly where the old one was located. Leave the wires in an easily accessible position.
Solder the wires in the corresponding places exactly where you disconnected them from the old logic board.
